Author Topic: how 2 reset immobiliser on omega 2.0i 16v 1999  (Read 1423 times)
mstickler
  • southampton
« on: 04 August 2009, 13:18:55 »
after charging my battery up over the weekend, put back on car & it wouldn't run, started first time on turn of key then after a few seconds just died. done a paperclip test yesterday & the code 1502 - immobiliser control unit can up is there a way to reset this or does it need to go on a reader or computer to reset it. thanks mark
Re: how 2 reset immobiliser on omega 2.0i 16v 1999
« Reply #1 on: 04 August 2009, 15:12:50 »
No way to reset it.....was teh ecu light flashing when the engine stopped?
Have you opened the key up recently?
mstickler
  • southampton
« Reply #2 on: 04 August 2009, 17:15:50 »
no haven't open key y should i
mstickler
  • southampton
« Reply #3 on: 04 August 2009, 17:17:15 »
no ecu light not flashing just done paperclip test & came up with code 1502
« Reply #4 on: 04 August 2009, 17:18:46 »
Just thought you might have opened up the key & dropped the chip from inside.  :y Are you using the same key as you usually use? If you have a 'favourite'/prefered key, try using that one.   :y  :y
mstickler
  • southampton
« Reply #5 on: 04 August 2009, 19:05:20 »
i have used both keys & tryed to reprogram them by turn on then waiting 30 seconds & then pressing lock/ unlock one at a time still no luck
« Reply #6 on: 04 August 2009, 19:12:48 »
You're only resetting the central locking by doing that. It's the chip in the key that's taliking to the alarm ECU that you need worry about.
mstickler
  • southampton
« Reply #7 on: 04 August 2009, 19:15:38 »
how do i get over this does it need to be reset with computer or reader
« Reply #8 on: 04 August 2009, 19:19:51 »
you need someone far more experienced in the electrics/imobilisers/etc than me.
Where in the country are you? There may be very well someone local to you  ....  :y
mstickler
  • southampton
« Reply #9 on: 05 August 2009, 20:46:06 »
i'm in southampton area
