Author Topic: Differences between 3 litre and 2.5 engine  (Read 1982 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 01 December 2007, 12:56:09 »
Just an idle thought but is it possible to rebuild a 2.5 as a 3 litre?
Is the extra capacity from a different crank or bigger pistons? I know the cams are different on the three litre. What else don't they share?
varche
Re: Differences between 3 litre and 2.5 engine
« Reply #1 on: 01 December 2007, 12:58:08 »
You'd need a different block and heads. So essentially a new engine!
Ancilliaries Im sure are all the same.
« Reply #2 on: 01 December 2007, 13:56:54 »
As James said, I think bore and stroke are different so practically all engine main components (block, heads, crank, rods, pistons, cams) will be different.
Best to start with the right engine.  :y
« Reply #3 on: 01 December 2007, 15:17:23 »
block, pistons, crank, heads, cams, valves. probably more...
« Reply #4 on: 02 December 2007, 22:53:24 »
Apart from them .... they're nearly the same!!!!!!!  ;D ;D ;D
