Author Topic: Crank sensor  (Read 2847 times)
1960darrenh
  • Kettering Northants
Crank sensor
« on: 06 August 2009, 20:01:59 »
Anyone know the CHEAPEST place to buy a Crank Sensor for a 2.5V6?
Ive scanned some internet site and am getting prices from £40 - £70.
    • E250 Est / Elroq
Re: Crank sensor
« Reply #1 on: 06 August 2009, 20:22:19 »
be aware on these cheap has often been proved to be false economy when they dont fix your problem.
most here would recommend genuine :
Omega        Part Number        Retail Price        Normal Trade        Trade Club
Crankshaft sensors
2.0 8v                                         90493864       £57.50       £51.76       £44.76
2.0 16v to 14194716                                      90458251       £57.50       £51.76       £44.76
2.0 16v from 14194717/31000001                                    9174621       £34.70       £31.28       £27.00
2.5 (early models)                                       90492006       £79.00       £71.10       £61.60
2.5 (later models)                                       90492061       £57.50       £51.76       £44.76
2.6/3.0/3.2                                        90540743       £51.50       £46.40       £39.92
2.0DTi/2.2DTi                                        90540188       £35.75       £32.18       £27.84
U25TD/X25TD                                        90487810       £82.50       £74.25       £64.45
all plus vat
Re: Crank sensor
« Reply #2 on: 06 August 2009, 20:48:22 »
Don't bother with a cheap one... You'll be replacing it again very quickly!
Check your part number... If it's the one ending 2006 I have a genuine one I picked up a bit cheaper that you can have for £50 delivered if that's any help. :y :y
Re: Crank sensor
« Reply #3 on: 06 August 2009, 21:04:43 »
As already said, genuine Vauxhall is the only way to go with these.
alank46
  • South Devon
    • 3L Elite Estate 1996
Re: Crank sensor
« Reply #4 on: 06 August 2009, 22:28:36 »
Hi
That's the one for my car, so yes please I'm interested if I've not been beaten to it. How would you like paying.
When mine went last time I replaced it with a cheapy, but it has worried me ever since.
Alan
Re: Crank sensor
« Reply #5 on: 06 August 2009, 22:49:18 »
Hi
Alan
I'll give the OP a chance first but if he doesn't want it then it's yours!
I didn't send it back because I got it cheap and thought someone could benefit :y :y :y
Oh, and because I'd opened the packaging in my eagerness to fit it before I checked the Part Numbers :-[ :-[ ::) ::)
1960darrenh
Re: Crank sensor
« Reply #6 on: 06 August 2009, 22:57:18 »
Hi
Alan
It's ok, let him have it. I think I've got one lined up. Thanks anyway  :y
alank46
  • South Devon
Re: Crank sensor
« Reply #7 on: 07 August 2009, 08:14:11 »
Hi Lazydocker
I'm having trouble sending a pm to you, can you pm me so I can reply advising my address.  How would you like paying, do you take Paypal.
Thanks
Re: Crank sensor
« Reply #8 on: 07 August 2009, 09:42:09 »
Buy the sensor from Vauxhall, cheap sensors are false economy, it won't last as long and you will end up replacing it a lot sooner
alank46
  • South Devon
Re: Crank sensor
« Reply #9 on: 07 August 2009, 14:49:17 »
The way I read it Lazydocker is offering a genuine Vx item at a lower cost, rather than a cheap aftermarket  item.  Its on that basis that I am buying it.
Alan
Re: Crank sensor
« Reply #10 on: 07 August 2009, 14:58:38 »
Alan
Crossed lines here, I think. I read it that Tunnie was advising against cheap pattern crank sensors. Lazydocker's is a genuine part bought in error so should do you fine. :y
Re: Crank sensor
« Reply #11 on: 07 August 2009, 15:56:40 »
Alan
Yes sorry bit of a mix up here, if Lazydockers is geniune thats fine. Just warning you against pattern sensors.  :y
Re: Crank sensor
« Reply #12 on: 07 August 2009, 21:28:45 »
Alan
Yep... Genuine part, supplied in error but was at a knock down price as it was "old" stock on the shelf so Andyc did me a deal ::) ::) :y :y
Seemed too good a price to return it as I knew that someone here would eventually benefit :y :y
Re: Crank sensor
« Reply #13 on: 08 August 2009, 15:34:22 »
Lazydockers is probably the wrong one for your car mate.  Yours is probably part nº 90492061, whick has a plastic sensor end and the oval elecy plug.
Page created in 0.023 seconds with 20 queries.
