Author Topic: rear diff  (Read 1440 times)
wild5179
  • hertfordshire
rear diff
« on: 08 August 2009, 17:59:08 »
would anyone be able to tell me if the diff off a 98 plate mv6 would be the same as a 2.5
serek
  • huntingdon
    • 3.2 mv6
Re: rear diff
« Reply #1 on: 08 August 2009, 18:34:33 »
will fit  :y if is manual to manual or auto to auto
wild5179
  • hertfordshire
Re: rear diff
« Reply #2 on: 08 August 2009, 18:37:48 »
thanks for the reply would it just be a normal diff and not an lsd
serek
  • huntingdon
    • 3.2 mv6
Re: rear diff
« Reply #3 on: 08 August 2009, 18:43:28 »
probaly normal , LSD are not standard fit to MV6
kcl
  • Finland
    • Volvo V60 D4 -14
Re: rear diff
« Reply #4 on: 08 August 2009, 18:43:40 »
All diffs will fit, physically, but there are quite a few different ratios depending on engine/gearbox combinations.
You have a 2,5 engine, so the replacement should come from a car with same engine and gearbox if you want to maintain the original ratio. Of course it is a good opportunity to make the car accelerate better with a higher ratio diff or achieve better mpg with a lower ratio...
IIRC there is a list of ratios on this forum but I'm so bad putting on any links...  :-/
wild5179
  • hertfordshire
Re: rear diff
« Reply #5 on: 08 August 2009, 18:46:35 »
thanks for the replys much appreciated
