Author Topic: steering wheel hot  (Read 1752 times)
trainastock
  • st neots  cambridgeshire
steering wheel hot
« on: 08 August 2009, 17:44:29 »
under the steering wheel were all the wires are ,just above were your kness are gets very hot ,everything works fine just hot to the touch
any ideas what the problem is  thanks  :y :y :y
Re: steering wheel hot
« Reply #1 on: 08 August 2009, 21:28:21 »
does it change if heater is off?
trainastock
« Reply #2 on: 08 August 2009, 23:13:25 »
no change when heater off
Agemo
  • Cleethorpes
  • Insignia
« Reply #3 on: 09 August 2009, 07:51:38 »
When you say "Where the wires are" do you mean the centre section? I am assuming the wires are the radio controls. These should not have power running through them as such. You have me baffled. A new steering wheel from one of our breakers would be a cheap option.
« Last Edit: 09 August 2009, 07:52:22 by Agemo »
trainastock
« Reply #4 on: 09 August 2009, 12:14:26 »
yes in the centre section radio looks like a area to look into
cheers :y
trainastock
« Reply #5 on: 10 August 2009, 02:03:14 »
just got back from long drive  with the radio off  big difference in the heat of underside of steering wheel
any ideas of a fix  thanks  :)
