Author Topic: Advice on what to buy for cambelt change???  (Read 1397 times)
Neil_MV6
  • Sutton Coldfield-West Midlands
« on: 11 August 2009, 20:45:49 »
Hi again.
Moving on from previous post, I've now found a supplier for a cambelt kit, thanks AndyC, now just a couple more questions:
2002 3.2 MV6 auto
1. Do I need to do the water pump at the same time as the cambelt?
2. What else do I need for the job?
Thanks guys  :y
Re: Advice on what to buy for cambelt change???
« Reply #1 on: 11 August 2009, 21:15:41 »
Waterpump if you don't know its history, and antifreeze if you change the waterpump.
Being a 3.2, you need to lift plenum, so may be worth having the 6 large o-rings, even if you don't use them (they can go hard, and not make a great seal)
Welung666
« Reply #2 on: 11 August 2009, 21:21:20 »
I agree with TB, change the O rings anyway, better safe than sorry but check they are seated correctly to save you having to pull the plenum back off to re-seat them :y
Pete Elite
  • Uxbridge, Middlesex
« Reply #3 on: 11 August 2009, 22:12:41 »
It may be worth fitting a new auxs. belt if you don't know it's age :).
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #4 on: 12 August 2009, 00:38:36 »
Not had to replace any O rings under the plenum yet :-?
« Reply #5 on: 12 August 2009, 09:56:59 »
Not a bad idea to remove the aux. belt tensioner pulley, carefully lift the seals out and re-grease the bearing. Mine was dry as a bone at the 80k change.
Neil_MV6
« Reply #6 on: 12 August 2009, 13:46:45 »
Thanks Kevin, made a note of that.
I might as well do the aux belt too, it's done 180k now. I had the plenum off not so long ago when i did the breathers and the O rings 'seemed' ok.
What would the symptoms be if they don't do their job properly?
« Last Edit: 12 August 2009, 13:47:15 by Neil_MV6 »
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #7 on: 12 August 2009, 13:53:12 »
Bad running, hissing sound from pleunum on idel.
He who brakes Looses
To old to die young
