Author Topic: Facelift Estate Headlining  (Read 873 times)
« on: 12 August 2009, 17:01:49 »
Anyone ever changed one?
Mine is filthy, I'd like to replace it :y
Welung666
Re: Facelift Estate Headlining
« Reply #1 on: 12 August 2009, 17:09:43 »
They are quite easy to change James, just time consuming taking all the pillar edgings off :y
« Reply #2 on: 12 August 2009, 17:13:31 »
That's reassuring, I had it down as being a right pain in the ass  ;D
Welung666
« Reply #3 on: 12 August 2009, 17:17:30 »
No! Start at the front, visors and centre panel off. A post mouldings, sunroof surround and both grab handles above the door off. both rear handles and lights. B post covers, a few roof clips. then load light and rear window surrounds. A gentle pull downwards and off she comes then just slide it out the tailgate. Classic Haynes to re-fit. If you're up my way I'll give you a hand :y
« Reply #4 on: 12 August 2009, 17:19:25 »
Cheers matey, might take you up on that  (After I've done the more important jobs, like, fitting a new engine ;D )
Welung666
« Reply #5 on: 12 August 2009, 17:22:24 »
Well obviously ;D ;D Unless you fancy pushing it up here ;D
