Author Topic: Scuttle drain .............  (Read 1616 times)
I_want_an_Omega
« on: 11 August 2009, 21:50:22 »
Hi all,
In working my way around my new toy I thought that I'd clean out the scuttle drain using the excellent guides here.
I was HORRIFIED to see that the thing was virtually full of mud - with a nice topping of leaves! The mud was dry &   compacted.
I started cleaning it out and eventually got to the drain plug. The problem is that I can't see how the drain plug drains as it seems a solid grommit is in the base. I can't see the front edge of the grommit & my arm is too fat to touch.
If I put some water in then it drains away very very slowly.
Before I try poking with the electical cable - I thought that I'd ask the obvious question - why not just remove the grommit totally or punch a big hole in it?
Any ideas/comments welcome.
Thanks .......... Rob
MutantCav
  • Gainsborough
Re: Scuttle drain .............
« Reply #1 on: 11 August 2009, 21:53:41 »
There is a drain...dont punch through the grommit, can show you tomorrow :y
I_want_an_Omega
« Reply #2 on: 11 August 2009, 22:00:19 »
Thanks mate ............
« Reply #3 on: 11 August 2009, 22:02:11 »
Pete Elite
  • Uxbridge, Middlesex
« Reply #4 on: 11 August 2009, 22:02:15 »
Hi Rob,
          It depends on what model year your Mega is.
 On the earlier cars the drain comes out inside the wheel arch behind the wheel(should see a rubber tube sticking out of the inner wing)so just stick something up the hole to clean it out :).
 On later cars it comes out in the engine compartment although not sure where as i have the earlier model :-/.
  You will find that the earlier models drainage route is a dog leg shape so not easy to poke anything straight down :(
          HTH,
                Pete :)
« Reply #5 on: 11 August 2009, 22:09:23 »
Does this help?  :y  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1167524083
That shows exactly where it is Andy, in face there's a hinged flap on the grommet.  You can reach down and pop it up with a finger (just) to clear the bottom of it.
There's not a great deal of room between it and the chassis leg however. :y
« Last Edit: 11 August 2009, 23:23:40 by Zulu77 »
I_want_an_Omega
« Reply #6 on: 11 August 2009, 23:06:55 »
Yes, this helps - thanks.
Its a '98 minifacelift BTW.
t seems that the drain in the grommit is on the front edge - so I'll try with cable tomorrow.
I'm gobsmacked that my car didn't suffer from an internal flood - who knows how long it had been like that!
Pete Elite
« Reply #7 on: 11 August 2009, 23:17:47 »
   Due to the damage it can do to heater components and interior it's certainly worth checking every now and then :y.
sneakypenguin
  • Birmingham
  • Xbox gamertag MagicGinjaninja
    • 07 Volvo V70 T5
« Reply #8 on: 12 August 2009, 00:30:48 »
may also be worth changing your pollen filter if it was that bad, when I got my car and found this wonderful site  :D  I did a a lot of reading and changed the coolant (which was practically black) and the pollen filter (also black). I check the skuttles every week and am constantly suprised to see the drivers one keeps getting blocked with leaves even though I don't park under a tree
07 Volvo V70 T5 SE ex police
I_want_an_Omega
« Reply #9 on: 12 August 2009, 17:01:06 »
Sorted!
Found the hole in the grommit - although couldn't actually see it, and poked some T&E cable through followed by some water to flush it out.
Thanks all .........
« Reply #10 on: 12 August 2009, 17:41:50 »
will you save it for the next time you're passing Swinton, Scottie might have use for it!  ;)  ;)  ;)  :y  :y  :y
sneakypenguin
  • Birmingham
    • 07 Volvo V70 T5
« Reply #11 on: 13 August 2009, 02:27:07 »
another good, cheap tool to use is an old toothbrush, gives you a bit of extra leverage and the brush head is about the right size
