Author Topic: engine running rough  (Read 1527 times)
omegatech
  • sheldon, birmingham
    • omega 2.2 cd petrol
« on: 09 August 2009, 21:48:00 »
hi there all
please can somebody help me i did my rocker cover gaskets today on my v6 and after many hours of doing the job i put the engine back together the exact way i had taken it  apart.
and when i started it up it started up no problems but after about 5 seconds it started to idle rough not as smooth as before. i cleaned all the breathers and the idle air control valve. i have gone over everything i done but cannot seem to find why it is doing it.
please help
Re: engine running rough
« Reply #1 on: 09 August 2009, 21:50:09 »
Have you trapped a wire, at the front of the right hand passenger bank??
I did exactly that and got the same results!  Very easy to do as the cable is black! ::) ::) ::)
Do a paperclip test if not ;) ;)
« Reply #2 on: 09 August 2009, 22:12:19 »
any fault codes stored?
omegatech
« Reply #3 on: 12 August 2009, 12:51:24 »
hi there
thanks for your replies
i know the wire you mean as it did play me up a bit  :'(  but i did manage to get it away enough to put the cover back on.
i will do the paper clip test as soon as it dries up abit.
i was also told to change the spark plugs and ht leads as the oil could have damaged them due to the oil covering them.
Welung666
« Reply #4 on: 12 August 2009, 13:47:13 »
It could be the leads/dispack but could also be an air leak at the plenum O rings. Any hissing noises round the plenum area with it ticking over?
omegatech
« Reply #5 on: 13 August 2009, 13:09:22 »
hi there
i started my engine to listen for any noises and there is a loudish type of rushing air sound could that be the o rings below the plenum come loose or out seated.
omegatech
« Reply #6 on: 13 August 2009, 13:10:32 »
sorry
the sound of the rushing air seems to be coming from the plenum end.
cheers
Welung666
« Reply #7 on: 13 August 2009, 13:35:13 »
Have you got any easy start or brake cleaner spray? If you have try a tiny squirt under the plenum near each cylinder. If the revs increase slightly on any of the pots then there is extra air getting in through the O ring :y
omegatech
« Reply #8 on: 13 August 2009, 18:58:20 »
hi there again
BINGO :) just to let you know the problem has been found after checking all the plenum rings and found they were all ok i decided to put it all back together and do it another day.
but it was when i was putting the top breather box back on i noticed the seal was missing where it fits into the top of the plenum after finding the seal thank god i fitted it back on the breather box and the 2 o rings were also damaged so i made a couple temporarily til i go to vauxhall and hey presto no rough idling.
many thanks to everyone for your help
