Author Topic: oil problem  (Read 2630 times)
bhoysnr
  • glasgow
oil problem
« on: 13 August 2009, 18:19:03 »
hi all
when starting my omega it sounds as if the oil is,nt getting to the top of the  engine quick enuff this goes on for about 5-6 seconds can any1 tell me the best way to cure the problem will adding something like stp oil additive help
 thanks in advance
Bumbazor
  • Worksop
Re: oil problem
« Reply #1 on: 13 August 2009, 18:35:50 »
Is is a tapping noise?
Sounds like you need an oil and filter change. When was it last done?
bhoysnr
  • glasgow
Re: oil problem
« Reply #2 on: 13 August 2009, 18:40:37 »
yes it is dont know when it was last done only had the car for 4 weeks
ScottieMV6
  • Swinton, Manchester
Re: oil problem
« Reply #3 on: 13 August 2009, 18:48:57 »
Oil and filter change required ASAP, would also recommend cam belt kit too unless you are sure it has been done within the last 4 years or 40000 miles.  :y
I'd rather be scared to death than bored to death!!
bhoysnr
  • glasgow
Re: oil problem
« Reply #4 on: 13 August 2009, 18:56:24 »
cam belt is that the 1 at the front of the engine coz ive seen a couple of cracks in that 1 can they be done at home or is there anything i need to know before starting it myself
Bumbazor
  • Worksop
Re: oil problem
« Reply #5 on: 13 August 2009, 18:58:49 »
That's right; unless you know and can be proved by receipts or service records, some things must be done ASAP, and the cam belt kit (belt AND tensioner and idlers) is one such highly important item. Also seriously consider doing the water pump too as it is really easy to do at the same time.
What history do you have for the car?
edit:
You can not see the cam belt without removing the cover. What you can see is the auxiliary belt, and for the sake of around £20 is worth doing if yours is cracked.
You can do all this at home but before jumping in to it, do some reading on the various guides on this forum and make sure you have all the tools; most important is the cam locking kit that must be used when changing the cam belt.
« Last Edit: 13 August 2009, 19:02:35 by Bumbazor »
bhoysnr
  • glasgow
Re: oil problem
« Reply #6 on: 13 August 2009, 19:02:54 »
dont have any history for it think i was lost due to its age its in immaculate condition for its year only trouble iv,e had is with the tick  over it kept cutting out but i just adjusted that and it seemed to work. you mentioned the tensioners and idlers but to be honest i dont know what they are and is it a separate belt for the water pump
smokingomega
  • Leeds
Re: oil problem
« Reply #7 on: 13 August 2009, 19:08:32 »
Could be the hydraulic tappets too. you can use some engine flush to clean it through before you change the oil.
I use forte engine flush, found it to be one of the best.
Bumbazor
  • Worksop
Re: oil problem
« Reply #8 on: 13 August 2009, 19:13:14 »
If you update your profile with more details about your car (engine size, spec) we will be better able to help, as some things are different between 4 pot and V6.
When you say you had trouble with tickover and you adjusted it, what exactly did you adjust?
Tensioners and idlers make sure any slack is taken up on the belt so it doesn't slip. These are often the first things to cause cam belt failure even if the belt itself is in good condition. Over time the belt stretches slightly and the tensioner is required to keep the right tension throughout its use. The idlers are used to make sure the timing is correct on the cams. Sloppy mechanics will sometimes only change the belt but leave the original tensioner and idlers, which is asking for trouble.
V6 engines use the aux belt for the water pump, 4 pots drive the pump with the cam belt.
bhoysnr
  • glasgow
Re: oil problem
« Reply #9 on: 13 August 2009, 19:35:35 »
ive updated the profile bumbazor do you know what i,m looking at in cost terms for all the suggestions ive had i will look into everything tomorrow hopefully get it done over the weekend
bhoysnr
  • glasgow
Re: oil problem
« Reply #10 on: 13 August 2009, 19:54:10 »
just to say thanks to every1 who pitched in with suggestions will probably try them all
           so thanks again guys  joe
Bumbazor
  • Worksop
Re: oil problem
« Reply #11 on: 13 August 2009, 19:58:45 »
Not sure about costs as it depends on whether you buy at full price or trade card.
Someone should be able to give you current prices if you ask nicely.
However as you have the 2 litre engine your water pump is driven by the cam belt.
I don't know exact prices but for oil change and filter, cam belt kit, aux belt, water pump, coolant (as you will need it when changing water pump), probably max £200 at full retail prices but you will have to check current prices as that figure was very roughly calculated!
bhoysnr
  • glasgow
Re: oil problem
« Reply #12 on: 13 August 2009, 20:00:09 »
just noticed you asked what i adjusted bumbazor it was the accelarator cable
Bumbazor
  • Worksop
Re: oil problem
« Reply #13 on: 13 August 2009, 20:14:55 »
I thought you will have adjusted that. It's often the wrong thing to do for an idling problem.
The real cause should be investigated and fixed. In your case the cause won't be a mis-adjusted cable and so your fix of adjusting the cable won't have removed the cause(s), and the problem could return if not fixed.
I don't know what the 2.0l 16v engines are like compared to v6 but the idle control valve (ICV) is one such possible cause of idling problems.
However I've never had a problem with idling but a quick search around these forums should give you some causes to look out for. Also it would help if you explained exactly what idling problems you had/have.
bhoysnr
  • glasgow
Re: oil problem
« Reply #14 on: 13 August 2009, 20:32:14 »
once the engine heated up, when braking to stop the eml came on and the engine cut out, seems to be an awful lot about the omega i dont know yet but i am willing to learn coz its such a joy to drive
