Author Topic: New box ... New problem  (Read 2005 times)
elite_one
  • Dunfermline, Scotland
« on: 14 August 2009, 10:25:22 »
Well finally got around to fitting my £20 2nd hand auto box ... runs ok , only thing is the gear change from 1-2 is a bit rough and when accelarating from lower speed e.g. at junction , r/abouts etc , seems to over rev before catching a gear ... any ideas , could replacing solenoids make a difference ???? Thanks in advance ... Ali
william01
Re: New box ... New problem
« Reply #1 on: 14 August 2009, 10:40:15 »
have you checked the fluid level?.
elite_one
« Reply #2 on: 14 August 2009, 10:49:53 »
atf level is fine ... fuild a lovely red colour   :y
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #3 on: 14 August 2009, 11:34:04 »
When you checked the fluid level was the oil warm and the engine running and you had put it through the gears (footbrake on obviously)  and the car level?
« Reply #4 on: 14 August 2009, 11:36:03 »
I would have taken the opportunity to change the fluid and clean/replace the filter before fitting the box that way you could have checked the thrust washer wasn't in bits before fitting the box ::)
elite_one
« Reply #5 on: 14 August 2009, 21:45:30 »
Never thought of that  :-[ :-[
got new gaskets so will give it a oil change and check :y
was starting to think torque conv. was goosed !!!
sassanach
  • trowbridge
« Reply #6 on: 14 August 2009, 22:53:21 »
if your tc was "goosed"you would be going nowhere.
elite_one
« Reply #7 on: 14 August 2009, 23:02:27 »
thats good news then ... i take it they don't  gradually wear out .... they just die
sassanach
  • trowbridge
« Reply #8 on: 14 August 2009, 23:14:32 »
got it in one,you would know if your tc was "goosed"by the need to wear ear muffs :y
