Author Topic: Omega 2.2 idle  (Read 1914 times)
Prelude
Omega 2.2 idle
« on: 12 August 2009, 15:50:40 »
Hello guys,
I really need some help here. My Omega 2.2 from 2000 has an erratic idle, the revs keep going up and down, sometimes the engine cuts out, looks like its misfiring, smells like unburnt gas on the exhaust and it vibrates a lot.
When running the vibration disappears, runs smooth but lacks power.
Opel says its the ignition coil, but i have tested it in a lab and it has over 40 kV output voltage, no problems.
The error codes are P100, P110 and P170.
Do you have any idea what might be wrong since my dealer doesn't.
Thanks for the help
Re: Omega 2.2 idle
« Reply #1 on: 12 August 2009, 16:06:18 »
Check the connection to the MAF as well as condition of the cabling
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: Omega 2.2 idle
« Reply #2 on: 12 August 2009, 16:08:45 »
p100 mass air flow sensor voltage high
p110 intake air temperature (iat) voltage low
p170 rich/lean exhaust
I would say you have a prob with your maf, have you tried unplugging it and see if theres any change?
He who brakes Looses
To old to die young
Prelude
Re: Omega 2.2 idle
« Reply #3 on: 12 August 2009, 16:20:52 »
Actually I have ordered a MAF on ebay but hasn't arrived yet to try.
I forgot to say that when the car was on the shop they found the spark plugs wells full of oil and have replaced the gasket.
Thanks for the help, I think I will find the solution here and do it my self, I have been in 2 dealers in the last 4 weeks and I  they have been very incompetent.
Regards
Re: Omega 2.2 idle
« Reply #4 on: 12 August 2009, 16:23:35 »
Regards
Genuine gaskets and O-rings I hope :y
« Last Edit: 12 August 2009, 16:24:00 by RobG »
Prelude
Re: Omega 2.2 idle
« Reply #5 on: 13 August 2009, 20:32:11 »
Well bad news keep coming.  A new MAF was tested and the problem persists. The intake and throttle valve was cleaned and the car has the same problem.
Any ideas how to solve this issue?
Thanks for the help
bigall
  • merseyside
Re: Omega 2.2 idle
« Reply #6 on: 14 August 2009, 11:54:06 »
the 2.2 is drive by wire , so first check the connections with the socket/s on the  throttle body are secure
then get the potentiometer/ throttle electronics tested - this if I remember requires tech2.
Unfortunately if this shows that the pot in the throttle body isnt working properly ie erratic idle then the only solution is a replacement throttle unit as the pot isnt accessible or repairable
I drive a moneypit Omega - at least its comfortable!!!!!  200k approaching rapidly!!!!!!!!! "") (must change oil soon)
Prelude
Re: Omega 2.2 idle
« Reply #7 on: 14 August 2009, 19:19:24 »
Do you know how my dealer can confirm if its a potenciometer problem on the car?
Is it possible its an Siemens ECU failure? I have read that this happens quite often.
Thanks
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
Re: Omega 2.2 idle
« Reply #8 on: 15 August 2009, 10:16:57 »
What about the EGR valve, mine had those symptoms prior to changing the EGR.
Omega 2.6 V6 Elite in Shiny Black
Prelude
Re: Omega 2.2 idle
« Reply #9 on: 15 August 2009, 12:36:10 »
Last time I was at dealer the egr valve was out and they said it was good. Mine is also at LPG, do you see a big increase in consumption comparative to gas?
Regards
