Author Topic: Identify factory fitted alarm in facelift  (Read 1268 times)
gsizoli
  • Hungary
« on: 15 August 2009, 19:06:47 »
Hi!
how can I identify if my car has inbuilt factory fitted alarm?It's a facelift and as i know there are no factory fitted alarm in it.But i've opened the keyfob and as I've seen it's a KIEKERT type which works with 433MHz (cars with factory fitted alarm)...so I don't understand....
Br
Zoli
Re: Identify factory fitted alarm in facelift
« Reply #1 on: 15 August 2009, 19:09:25 »
Have you a switch with a red LED on it by the TC switch on the radio console. If yes, then you have an alarm, and if it doesn`t work then the horn/powersounder has been disconnected
« Last Edit: 15 August 2009, 19:10:38 by RobG »
gsizoli
  • Hungary
« Reply #2 on: 15 August 2009, 19:23:34 »
I've no red led on the centre console...and 'i 've no sensors on the interior light too....but how does it posible if my keyfob is the KIEKERT TYPE???I don't really understand...
Does anbody can tell me what is needed for the factory fitted alarm?And what is the GM number for the central controller unit in case of factory fitted and non fitted alarm cars?
Br
Zoli
minimeee
« Reply #3 on: 16 August 2009, 23:35:01 »
How would 1 go about re-conmnecting the horn/power sounder btw??
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #4 on: 17 August 2009, 00:14:12 »
It may have been dis-conneceted as it was causing the alarm to sound for no reason other than P/Sounder batteries were failing, so be warned.
See here: http://www.omegaowners.com/forum/YaBB.pl?num=1220198611
