Author Topic: breather on top of plenum  (Read 1391 times)
samrey4u
  • norwich
  • Big stranglers fan
    • 2003 2.2 cd saloon
« on: 17 August 2009, 20:08:25 »
how do i remove breather box on top of plenum ? need to remove to clear out breathers also what other breathers do i do and is there a guide on here ? :-/
sam
Re: breather on top of plenum
« Reply #1 on: 17 August 2009, 20:10:04 »
sure there is a guide for this, but the top of the black Vx strip will just pop off, put a flat head screw driver under neath. The breather section is held down by a torx bolt iic, just pop that off.
Its Best to remove the throttle body as well
Toby
  • Ringwood, Hampshire
« Reply #2 on: 17 August 2009, 20:11:23 »
There is a guide in the Maintainence Guide section.
Basically though. Remove plenum, prise of the black cover (there is actually a cover on top of the breather box itself) Undo the screw. Give em a clean as well as all the pipes. Separate the throttles and clean them too.
Tis all in the guide...very easy to follow too
« Last Edit: 17 August 2009, 20:11:45 by Toby »
samrey4u
  • norwich
« Reply #3 on: 17 August 2009, 20:12:11 »
:y and which others need clearing ?
sam
Toby
« Reply #4 on: 17 August 2009, 20:15:21 »
samrey4u
  • norwich
« Reply #5 on: 17 August 2009, 20:39:03 »
http://www.omegaowners.com/forum/YaBB.pl?num=1152598350
All in there.  :y
many thanks toby  :y
sam
Page created in 0.02 seconds with 14 queries.
