Author Topic: Cleaning headlamps - best options please?  (Read 3442 times)
AndySnapper
« on: 17 August 2009, 15:05:01 »
The headlamp lenses on my Omega have become very dull and dirty over the years, is there a recommended way of restoring them to clarity again?
Thanks!
Andy
amba
  • Medway towns
    • German V6
Re: Cleaning headlamps - best options please?
« Reply #1 on: 17 August 2009, 15:19:57 »
Some people have had success with TC and lots of polishing,fine wet,n,dry and then final polish with G8 compound.
I found that mine were so bad that the easiest option was to buy a new pair of lights as cheap as possible on fleabay and then change the lenses over as my original units are HID,s.
Result is great but there is a cost implication involved.I wish you the best of luck with them.
samrey4u
  • norwich
  • Big stranglers fan
    • 2003 2.2 cd saloon
« Reply #2 on: 17 August 2009, 15:45:02 »
Ive heard that using t cut also works very well :y
« Last Edit: 17 August 2009, 15:45:16 by samrey4u »
sam
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #3 on: 17 August 2009, 15:55:57 »
I used T-cut on my previous Omega headlights and it brought them up quite well. :y
« Reply #4 on: 17 August 2009, 16:24:26 »
Cutting compound or if they are really bad 1500 wet and dry with warm soapy water then cutting compound :y
AndySnapper
« Reply #6 on: 18 August 2009, 17:57:33 »
Thanks! I appreciate all your replies.
I had tried using T Cut (by hand) but got a little worried that I might be doing more harm than good. It certainly did start to work on the film but the lens remained discoloured and dull. I hadn't thought of using Solvol Autosol though so will try on a small section first. Will find some of this plastic polish as well.
I'll let you know how I get on as it might help others as well.
Cheers!
Andy  :y
secarianu
  • Constanza, Romania
« Reply #7 on: 18 August 2009, 22:39:27 »
Hello guys! You can use XERAPOL product wich is a polish for plastics and abrasive tape 2000. To see the results, see the clubopel.com link http://www.clubopel.com/viewtopic.php?t=29204&highlight=xerapol
« Last Edit: 18 August 2009, 22:41:15 by secarianu »
"SPLENDID" OMEGA Y22DTH
***THE QUEEN***
Omegadoha, Desert Member
  • Doha, Qatar
« Reply #8 on: 19 August 2009, 04:49:42 »
It really depends on how badly they are gone. Probably in the UK, I'm sure you could restore them with a combintation of T-Cut or rubbing compund/polishing compound/ Brasso or plastic polish. In the Middle East they get really bad and even sanding them down may temporarily reveal a new facade it doesn't last vey long and quickly discolours again.
If you do rub them down, I'm not sure if you will retain the original clarity of the lens. I don't know if there is some kind of polycarbonate coating that you maybe removing?
I paid 125 quid for a pair of DEPO headlight units, and even if they last me a year I'll be happy.
Radiomarko
  • Sunny Devon
« Reply #9 on: 19 August 2009, 17:46:27 »
Ive just done the job in prep for MOT in a couple of months. I bought a wee bottle of "Greygate Plastic Polish" as used by NATO on fighter plexiglass from Fleabay. An hours hard rubbing ( they cant touch you for it  ::)  ) and 100% better - ah look bulbs in there!
I had tried T Cut before with little result.
I hate seagulls.
