Author Topic: Air con  (Read 1618 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Air con
« on: 15 August 2009, 20:08:55 »
tried to have my air con gassed on Friday :y
the man couldn't get anymore then 250 pounds of gas in there
how much presure is supposed to be in there ?
if it's blocked.    Any idea where ?
The system has been empty for 9 months
Cheers.  Steve
Re: Air con
« Reply #1 on: 15 August 2009, 20:27:51 »
Cheers.  Steve
If the system was empty Steve that usually means you had a leak. :-/ :-/
Was it repaired before refilling? :-/
« Last Edit: 15 August 2009, 20:28:22 by Lizzie_Zoom »
Omegadoha, Desert Member
  • Doha, Qatar
Re: Air con
« Reply #2 on: 15 August 2009, 20:41:07 »
If the gas is leaking out very fast, chances are it is not a valve. If it a case of a replacing pipework, it could work out a bit expensive.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Air con
« Reply #3 on: 15 August 2009, 21:52:20 »
Der man had to realy force in 250 pounds  :(
system holding at that presure
he just can't seem to get anymore gas in  :(
engine was re built by the previous owner
Re: Air con
« Reply #4 on: 16 August 2009, 02:15:09 »
Get an aircon specialist to look mate - 250 pounds????? You normally fill to a weight of gas substantially less than that!!! IIRC its 960gms.
Sounds like yours has been regassed by a cowboy
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Air con
« Reply #5 on: 18 August 2009, 12:23:24 »
Whoops.        Gms not pounds
my c@ck up ::)   :-[ :-[
Re: Air con
« Reply #6 on: 18 August 2009, 12:30:46 »
Did he actually vacuum test it first?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Air con
« Reply #7 on: 18 August 2009, 18:19:04 »
Not sure
I went walk a bout
when I got back he only had managed to get 50 in the system
it held at that presure
I explaned about the history Of the system so he increased the input pressure.
250 was the most he could force in.
Sounds to me like something is blocked or seased.
 Ideas anyone ??
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Air con
« Reply #8 on: 18 August 2009, 18:46:11 »
Sounds more like the bloke didnt know what he was doing. If he vac'd the system then he should have there as a problem before trying to refill. Proper air con equipment is very intelligent to these things but is let down by the idiot trying to use it.
Jaguar XJ6
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Air con
« Reply #9 on: 20 August 2009, 00:12:41 »
Anybody know a decent air con man in the hull area ?
Or even better, around skegness.  I'm here on holiday till next Tuesday.
Went to cromer today and the temp hit 31 degree's.
If I don't get it sorted soon I'll chuffin melt  >:(
