Author Topic: Coolant light  (Read 1363 times)
hollywood
  • michigan USA
Coolant light
« on: 20 August 2009, 17:16:32 »
I read a long time ago about cleaning something if you had the coolant light on. I cant find that post again =(.
My coolant level is fine, but the light is still on showing its low.
Anyone remember what it is you can do about it?
thanks,
Dave
2001 Catera
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
Re: Coolant light
« Reply #1 on: 20 August 2009, 17:20:11 »
coolant level sensor on side of header tank?
PM with your requests.
Re: Coolant light
« Reply #2 on: 20 August 2009, 17:34:57 »
thanks,
Dave
2001 Catera
The level sensor is integral to the header tank and can't really be removed by itself for cleaning. I had limited success by soaking the whole ting in a bucket of caustic solution. The only real cure is a shiney new header tank ...... in the UK they're around £35
I_want_an_Omega
Re: Coolant light
« Reply #3 on: 21 August 2009, 07:34:51 »
I have a spare one in good condition. If you are interested them PM me with an offer.
regds ........... Rob
Re: Coolant light
« Reply #4 on: 21 August 2009, 08:16:49 »
Rob!  8-)
'Hollywood' is in the USA ...... not really worth sending 2nd hand bits over.  ;)  ;)  ;)
« Last Edit: 21 August 2009, 08:17:10 by Andy_B »
Re: Coolant light
« Reply #5 on: 21 August 2009, 08:21:58 »
The sensor at the bottom of the header tank is removable, flat head screw driver will help. But can often break. Sounds like replacement sensor is needed. Something that small should be cheap enough to send to the states.
Re: Coolant light
« Reply #6 on: 21 August 2009, 08:24:41 »
........ Something that small should be cheap enough to send to the states.
You buy a complete tank though .....  ;)
Re: Coolant light
« Reply #7 on: 21 August 2009, 08:29:52 »
Fitting a replacement sensor on its own is easy, if the sensor can be removed without damage that can be sent. Without tank attached.
hollywood
  • michigan USA
Re: Coolant light
« Reply #8 on: 21 August 2009, 09:25:35 »
thanks for the help and the offers. I however have another car that doesnt have that light on that im using for parts. I just thought it was a cleanup fix. I guess ill try to remove the sensor off that one and put it on mine.
Re: Coolant light
« Reply #9 on: 21 August 2009, 09:28:34 »
Just swap the complete header tank, it's only a clip on the wing (fender? :-/) and a couple of hoses.  :y :y
Re: Coolant light
« Reply #10 on: 21 August 2009, 11:54:01 »
yeah if you have a spare tank, just swap that over...
