Author Topic: Air vent temperatures  (Read 1191 times)
Bumbazor
  • Worksop
« on: 21 August 2009, 10:11:04 »
Should all the front air vents be the same temperature?
For example when set to 24, the side vent is warm but the middle is cold. Is this correct?
Rob James
  • Sheffield
Re: Air vent temperatures
« Reply #1 on: 21 August 2009, 15:23:57 »
Yep, that is correct. Cool air on your face and warmer air on your body, or that is the idea I think.
bigdods
  • Brackley
« Reply #2 on: 21 August 2009, 19:17:10 »
Nope. On both miggys I have owned air is the same temp from all the face level vents.
Omegadoha, Desert Member
  • Doha, Qatar
« Reply #3 on: 21 August 2009, 19:27:39 »
I'm sure I have had differing temps on mine but defo on the Ford Scorpio.
  • Auckland
    • Mazda MPV
« Reply #4 on: 21 August 2009, 19:54:24 »
On my Carlton (Omega A) the temperature was controlled by a mixing flap. IIRC hot air came in at the bottom and cold at the top. The central vents were fed by a duct from the top of the mixing box and there was a cut out in the mixing flap so that when the flap was set to full heat a little cold air still came through so the central vents would be cooler than the other vents when heating. When set to cold all the vents were at the same temperature.
My assumption is that the Omega B carries on with a similar design that results in a little cold air being mixed into the central face vents at all times.
