Author Topic: HBV  (Read 2617 times)
Re: HBV
« Reply #15 on: 21 August 2009, 22:41:16 »
i think, depending how it fails it can do.
would appear not in my case.
im gonna check live data on 2 similar cars, and if i can see anything else, then its into an aircon place.
hbv fine, vac seems fine, motors and flaps all working as thy should, revs alter with aircon on / off.
Well, looks like am gonna try my luck with a new HBV then. Do you know how often the dryer should be changed?
afaik you can check the hbv....take it out and check its not leaking, you can check the plunger moves bu sucking on the vac connector.
mine had started leaking, but worked ok.
dunno on the dryer though sorry.
Looks like the scuttle panel is going out on Sunday then  :D I'll change the dryer anyway and will let you know if that helps the cooling  :y
be a devil....try it with the scuttle on  :y
Ziad
  • Bahrain
Re: HBV
« Reply #16 on: 21 August 2009, 22:44:21 »
Well, i'll assess first if trying that with the scuttle on leaves me hands bloody. Will be back with news sometime on monday  :y
