Author Topic: suggestions for protecting dispack from water drip  (Read 937 times)
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« on: 22 August 2009, 20:40:17 »
i know this is a common problem, but short of relocating the dispack on a v6 are what suggestions do you have re protecting it from the drips of water that collect on that rubbish spongey bit on the underside of the scuttle? is there a way of preventing the spongey thing from getting wet?
PM with your requests.
Welung666
Re: suggestions for protecting dispack from water drip
« Reply #1 on: 22 August 2009, 22:21:55 »
The common "cure" for the damp sponge under the joint in the skuttle is to run a bead of sealant (common bathroom silicone will do) down the joint in the 2 halves of the skuttle :y
humbucker
  • Cambridgeshire
« Reply #2 on: 22 August 2009, 22:41:53 »
you mean where the two separate scuttle pieces meet? bond them together with sealant?
