Author Topic: problem with steering  (Read 1593 times)
carpet wagon
« on: 22 August 2009, 12:18:54 »
Can any body shed any light on a problem I have with my 1999 estate
when the brakes are applied the car steers to the left or to the right, I have had the front whishbones checked out, changed track rod ends, and had new doughnut bushes on the rear, but the problem still remains
Any thoughts anybody
« Last Edit: 22 August 2009, 12:20:01 by paul_brannon »
unlucky mark mv6
  • tipton,west mids
Re: problem with steering
« Reply #1 on: 22 August 2009, 12:24:10 »
Possibly a problem with the brake calipers mate :-/
carpet wagon
« Reply #2 on: 22 August 2009, 12:33:57 »
Hi MarkMV6
Garage say its not the calipers
Im wondering if it could be the steering idler?
unlucky mark mv6
  • tipton,west mids
« Reply #3 on: 22 August 2009, 12:39:22 »
Hi MarkMV6
Worth a try mate,but just beware of these backstreet garages as they fob you off with anything if they havent got a clue as to what the problem is.Not saying they are cowboys,just something to beware of mate. :y
carpet wagon
« Reply #4 on: 22 August 2009, 13:17:04 »
Thanks MarkMV6
Point taken, There not a bad bunch - its a process of elimination though, It does pull the wheel out of yours hands when you hit the brakes so Im abit inclinded to think there right about the calipers, the steering idler is just what ive learnt from reading other forum sites
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #5 on: 22 August 2009, 17:47:15 »
IT sounds more like the wishbone bushes are shot  despite what the garage tells you mate, change the bushes and get the cars geometery set up by  a specalist company[ not just tracking ]WIM at chesham is the place to go for that job. The steering idler will give you the feel of lots of play in the steering wheel.
The bushes stop the arm and the wheel trying to move backwards when you use the brakes. The bushes are avalible to buy and they will need a press to push the old ones out and new ones in.
Gary  :y
« Last Edit: 22 August 2009, 17:48:08 by ffcgary1 »
Jaguar XJ6
ffcgary1
  • Mitcham,Surrey.
« Reply #6 on: 22 August 2009, 17:51:00 »
CW please update your profile as to your location  as there maybe a member local to you who maybe able to give you some advice on the problem.
Jaguar XJ6
Pete Elite
  • Uxbridge, Middlesex
« Reply #7 on: 23 August 2009, 00:50:23 »
If you find the Idler and wishbone bushes are OK then i would be inclined to check the slides on the front calipers are not seized :).
goonv6
« Reply #8 on: 23 August 2009, 10:14:05 »
I'd say idler first too. Had the same problem on my Camaro. The bushes will accentuate the problem too. The brake suggestion is a good one and not difficult to do, so I'd just do that one straight away.
ffcgary1
  • Mitcham,Surrey.
« Reply #9 on: 23 August 2009, 12:22:38 »
I dont agree with the idler arm theory here, it does not have any effect on the amount of travel the wisbones will try to move back in the wheel arch, it will however determin how much free play you have at the steering wheel. If it is not the calipers sticking then the bushes are indeed the next culprit.
Are the pads wearing evenly on both sides of the car?  if not then the worn side is binding on.
Jaguar XJ6
« Reply #10 on: 23 August 2009, 18:08:51 »
Agreed - check this first  :y
