Author Topic: Starting from cold  (Read 2016 times)
Erzy
  • Hull
  • Smooth kid !!!
Starting from cold
« on: 27 July 2009, 07:13:46 »
Is there anyone remotely near the Hull area who could look over my 2.2 for some serious beer tokens. Idles too high on start up then sounds loud for a few minutes until warm then everything is fine, if you stick it in D while still cool it struggles not to stall. Had it in two garage but they dont know and there was no codes, also sailed through MOT but I maintain it sounds ruff cold. >:(
Easy now, theres only one Lanny, the original - the mine!
richardirv
  • Leeds, West Yorkshire
    • Omega 2.6 MV6 2002
Re: Starting from cold
« Reply #1 on: 27 July 2009, 16:12:14 »
I am not an expert but that sounds similar to the problems I have had in recent weeks apart from it sounding loud. The MAF was my problem. But you would expect it to bring on the EML if it was.
richardirv
« Reply #2 on: 28 July 2009, 17:12:53 »
Just thought i'd bump this up, would of thought someone would have some more ideas  :y
Erzy
  • Hull
  • Smooth kid !!!
« Reply #3 on: 29 July 2009, 07:37:23 »
Could it be the throttle body making the noise, like I say the revs are only high when starting from cold. No garage seems to want to help!!!  Any OOFers out there fancy the job. ;)
richardirv
« Reply #4 on: 29 July 2009, 10:56:22 »
Your best bet would probably be markeymark as he is only in SLady bitshorpe.
Erzy
  • Hull
  • Smooth kid !!!
« Reply #5 on: 29 July 2009, 11:54:39 »
Cheers richardirv, I'll see if he checks in on this thread. You say yours was sorted by changing the MAF - but your engine did'nt sound noisy at all ?
richardirv
« Reply #6 on: 29 July 2009, 12:02:51 »
Yeah, when I had a MAF on that was not working right, I had major troubles when starting cold in a morning, it always started fine but after a few seconds the idle would go up and down then get much worse when put into D and was like trying to stall, and if revved a few times, it then seemed ok. I'm not saying this is the same problem exactly but I changed the throttle body after the error codes pointed me in that direction when it was actually the MAF at fault. Don't forget mine is a v6 too so that might change things.
I also noticed when I had a MAF on that didn't work at all, the idle would be high for a few seconds just after starting.
Check out the Thread "Broken down" it might help.
« Last Edit: 29 July 2009, 12:04:43 by richardirv »
Ian_D
  • York
« Reply #7 on: 31 July 2009, 16:03:06 »
I can have a look for you if you fancy a drive to York? ;)
[size=12]
Erzy
  • Hull
  • Smooth kid !!!
« Reply #8 on: 17 August 2009, 22:24:59 »
Cheers Ian.D will defo take you up  on that. Been working away for a fortnight but good to go from now, let me know when your valuable services are available my good man ;D
Erzy
  • Hull
  • Smooth kid !!!
« Reply #9 on: 23 August 2009, 22:45:24 »
Mines a 2.2 mate don't forget, it's definately getting louder when starting from cold . Would love to come through and have you look it over, got the week off work so pm me if you want to set it up. :y
