Author Topic: Removing the CAT  (Read 982 times)
capoMV6
Removing the CAT
« on: 24 August 2009, 00:54:30 »
Need your comments guys.
If I remove the CATS (both of them) and replace them with 3/8 pipes to connect the exhaust, what would be the effect?  Also what happens to the sensors attached to them? Can I just short them out by attaching a wire so that it seems as they are still connected to the CAT?
Thanks.
Re: Removing the CAT
« Reply #1 on: 24 August 2009, 01:05:28 »
The car wont pass the MOT,other than that,not sure.I suspect it might give it a bit more grunt. :-/
Pete Elite
  • Uxbridge, Middlesex
« Reply #2 on: 24 August 2009, 01:17:33 »
The cats have nothing to with the sensors, they are there to tell the ECU that the engine is getting the correct fueling :).
 You have to just remove the cats and leave the front pipes on, but as said it won't pass an MOT :(.
