Author Topic: Oil in plug wells  (Read 1738 times)
Ryan Hegarty
  • Kesh, County Fermanagh, N.I.
Oil in plug wells
« on: 24 August 2009, 20:45:43 »
Hi all decided to change spark plugs in the 2.5 V6 Omega today to find that on two of the passenger side plug wells (not the middle one) there was oil in them, not too much in the front one but quite a bit in the back one - what's your thoughts? - drivers side clean as a whistle.
Arrolman
  • Renfrew,Scotland
Re: Oil in plug wells
« Reply #1 on: 24 August 2009, 20:48:36 »
Hi,
More than likely your cam cover gaskets are leaking/breathers blocked
Cheers,
Iain
Looking to win the lottery..........
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #2 on: 24 August 2009, 20:50:11 »
Failed cam cover gasket :y
Trade club card holder
Code scanner available
Ryan Hegarty
« Reply #3 on: 24 August 2009, 20:56:51 »
I changed oil about a fortnight ago so oil is nice and clean although oil in plug wells is dirty.
Is there any way of checking if breathers are blocked - someone suggested if oil is spitting from dipstick that is an indicator. :'(
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #4 on: 24 August 2009, 21:55:01 »
best way is to remove breather pipes and look at crankcase breather box / see if pipes blocked. then check breather channels through plenum cover. worth checking/cleaning these every 18 months to prevent cam cover leak and oil in spark wells... when was the last time your breathers were cleaned? if more than a couple of years you should clean them as a matter of course
« Last Edit: 24 August 2009, 21:56:20 by ilovemyelite »
PM with your requests.
Pete Elite
  • Uxbridge, Middlesex
« Reply #5 on: 24 August 2009, 23:05:15 »
Read the section on cleaning breather system in the maintenance section and when you replace the camcover gaskets use only genuine parts as cheap pattern parts don't last long :y.
