Author Topic: whats broken now .no speedo  (Read 1896 times)
cossienick
« on: 24 August 2009, 14:13:31 »
driving home today and the speedo, rev counter fuel gauge , tc, and display and temp  isnt working   . also the batt light is on , any ideas what it is. also the window is down and wont go back up..and its raining has a fuse blown i cant see one tbh or is this gona be expensive .
ohh its on a s reg elite estate
thanx nick.
sneakypenguin
  • Birmingham
  • Xbox gamertag MagicGinjaninja
    • 07 Volvo V70 T5
Re: whats broken now .no speedo
« Reply #1 on: 24 August 2009, 14:28:02 »
sounds like it's a fuse, have a look under the steering column.
07 Volvo V70 T5 SE ex police
« Reply #2 on: 24 August 2009, 14:33:51 »
Sounds like a load of fuse's. I would check for loose wiring/earths.
brucellosis
  • n.i
« Reply #3 on: 24 August 2009, 14:39:57 »
my temp guage an rev counter stopped working on way home form work on fri, i tapped the counter a few hard knocks with my finger and it worked, was just stuck  :o ...!!
Ziad
  • Bahrain
« Reply #4 on: 24 August 2009, 14:42:30 »
brucellosis, Sounds like the connectors at the back of the instrument panel as loose. Try to push the instrument panel in gently (put your hand each at one side). It may help  :y
« Last Edit: 24 August 2009, 14:43:30 by ziad »
cossienick
« Reply #5 on: 24 August 2009, 14:43:05 »
mmm well i have managed to close the window with the key fob. no luck on anything else just yet . keep the suggestions coming thanx
brucellosis
  • n.i
« Reply #6 on: 24 August 2009, 14:46:13 »
cheers Ziad, i'll give it a shot  :y
Ziad
  • Bahrain
« Reply #7 on: 24 August 2009, 14:51:36 »
Keep us posted mate  :y
« Reply #8 on: 24 August 2009, 14:56:27 »
thanx nick.
When that happened to me whilst carrying maintenance it was a fuse (12??)  that had blown ;) ;)
But why yours has blown whilst going along is the question :(.
cossienick
« Reply #9 on: 24 August 2009, 16:16:53 »
all fueses under stearing ok all fuses under bonnet by the batt ok. is ther any more hidden away anywere.
batt is at 12v and charging at 14v and less than 6months old.
i have no dash lights when ignition is turned on. but when started the battery light is on constant.
still no electric windows.
anyone any more ideas i could try.
cossienick
« Reply #10 on: 25 August 2009, 00:01:45 »
up for the nightime ppl.
