Author Topic: Windscreen Replacement - Autoglass  (Read 1842 times)
belldarr
« on: 24 August 2009, 17:26:04 »
I have just arranged Autoglass to come and fit a replacement windscreen to my Elite - I was just wondering if they should replace the trim/rubber part as well when replacing - does anyone know??
May seem a daft question to some but I know that the last screen I had fitted to a 7 series BMW needed new trims as you couldn't re-use the originals without risking windnoise and leaks.
Darren  :y
valliant72
  • London
Re: Windscreen Replacement - Autoglass
« Reply #1 on: 24 August 2009, 17:38:39 »
Had my windscreen changed just over a week ago, due to kids throwing stones. Cracked it right in the middle of the field of view. When they changed it the rubber was ok but they tried to keep the old seals but they wouldn't hold so they replaced them. The external rubber seal was re-used
« Reply #2 on: 24 August 2009, 18:23:45 »
Autoglass replaced all my seals / rubbers when they did my screen last month ;)
« Reply #3 on: 24 August 2009, 21:35:18 »
Autowindscreens have replaced the top/side trim with new but had to re-use the bottom one both times as they can't get them ::) ::)
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #4 on: 24 August 2009, 21:37:50 »
They should replace the seals wherever possible as if they put the old ones back they can become distorted & pop out in the future  :y
Previous GM Models include '00 Omega 2.5 CD Auto, '06 Holden Commodore Executive 3.6 Auto, '99 Astra 1.8 CDX Auto, several Astra Diesels.
« Reply #5 on: 24 August 2009, 21:43:23 »
That's interesting!
Our Ashford Autoglass replaced seals 6261ASMS and 6261AKOS, and all is new 8-) 8-).  Is there another seal involved? :-/ :-/
« Reply #6 on: 24 August 2009, 21:44:11 »
Autoglass did mine last week - replaced all seals apart from bottom and external rubber seal (can't get either from Vx or elsewhere easily)
MarkG
  • Northwich, Cheshire
  • "An Omega? Been a while since I saw one of those!"
    • 2000 CD 2.5 V6
« Reply #7 on: 24 August 2009, 22:46:12 »
National re-used my old trim and seal. They had to come back twice to fix it. Once to replace the seals because they had broken one side removing it (causing wind noise) and then again to replace the trim because it kept popping off. Autoglass came to do my wife's Laguna at the week-end and automatically replaced everything. Seems to be Autoglass policy. No problems at all with it!
belldarr
« Reply #8 on: 25 August 2009, 10:47:32 »
Thanks for all the replies - I guess I shall have to supervise the fitter to make sure that he replaces everything to my complete satisfaction  ;D
Darren
