Author Topic: another stalling problem  (Read 1046 times)
kjf7
  • lincolnshire
« on: 24 August 2009, 23:53:23 »
it did this for the 2nd time today same as 1st coming up to a roundabout, take the revs off changing gear and all that jazz, look down dash lights are on then starts fine whats going on with the bugger :-/
« Last Edit: 24 August 2009, 23:54:47 by kjfomega »
Re: another stalling problem
« Reply #1 on: 25 August 2009, 21:31:38 »
one for the td owners....
spikerz
  • Perth,Scotland
« Reply #2 on: 26 August 2009, 09:28:05 »
should do a paperclip test to see what fault codes come up- http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
i still cant solve my stalling problem and while trying to fix it i have....
changed crank sensor-had code 19
replaced vacuum pipes-were perished.
replaced battery-was too small.
replaced alternator-noisy bearings.
checked/cleaned all earths.
checked/cleaned EGR valve.
checked/sprayed with electrical cleaner all electrical connections.
replaced air filter.
replaced in-tank lift pump-motor was dead and clogged up,drained/cleaned tank,fresh fuel.
replaced and (filled with diesel magic) fuel filter.
and..still stalling.
