Author Topic: td turbo gate ?  (Read 1065 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
td turbo gate ?
« on: 26 August 2009, 14:02:11 »
how do i find out if the gate is sticking on my td turbo & on the presumtion it is how do i put it right ?. advice is much appreciated ta :)
Re: td turbo gate ?
« Reply #1 on: 26 August 2009, 14:07:25 »
Gte under the car and try moving it by hand.
Its a mega basic setup, the gate is kept closed unless the inlet pressure builds to the point where the pressure actuator on the turbo output starts to open it. Totaly self contained.
Re: td turbo gate ?
« Reply #2 on: 26 August 2009, 18:33:25 »
Exactly as MDTM says, its a simple setup on these, check the arm moves freely.
Why do you expect its stuck - no boost or over boost?
raywilb
    • Citroen C4 Cactus
Re: td turbo gate ?
« Reply #3 on: 27 August 2009, 00:48:07 »
seems lacking boost a bit , plus a new code 44 incorrect boost pressure. oil all over the radiator blowing from turbo me thinks , want to cure it. :y
