Author Topic: changing abs sensor  (Read 970 times)
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
changing abs sensor
« on: 28 August 2009, 07:15:19 »
as above, after replacing do the warning lights go out on there own or will the codes need clearing with tech 2.  :y
sharky
  • west sussex
Re: changing abs sensor
« Reply #1 on: 28 August 2009, 11:39:44 »
I had similar problem, thought it was sensors as ABS + T/C lights were on, tried a front and rear sensor and cleaned others but to no avail, turned out to be the ABS ecu, signs are no speedo, heavier steering and obviously no ABS or T/C, do you have these symtems??
The Red Baron
« Reply #2 on: 28 August 2009, 13:15:51 »
ecu is new, has been tech 2`d & is o/s/f sensor.  :)
