Author Topic: Drivers door bangs when l hit a pot hole  (Read 1407 times)
Gary W
  • Romford. Essex
« on: 26 August 2009, 17:31:25 »
My drivers door makes a loud bang, clunk type noise when l hit a pot hole. lt sounds like the door isnt shut properly but it is. l have checked the latch and catch but they are tight.
Any ideas of what is loose ?.
Gary
Nature dictates that we grow old. But its a choice to grow up, and l coose not to.
Re: Drivers door bangs when l hit a pot hole
« Reply #1 on: 26 August 2009, 17:34:26 »
Sure its the door?
alank46
  • South Devon
    • 3L Elite Estate 1996
« Reply #2 on: 26 August 2009, 17:42:27 »
Mine did this when I first bought it.  I moved the latch inwards so the door compressed the seals more and that stopped it.
Alan
Gary
MickAP
  • South Derbyshire
« Reply #3 on: 26 August 2009, 17:47:41 »
Same here as above post try adjusting the striker plate.
Mine made a sort of sqeaking noise, as if the door was loose against the rubber sealing strip, drives you mad after a while, all sorted now.
Mick
wakeyomega
  • Wakefield
« Reply #4 on: 26 August 2009, 18:49:45 »
I had a really annoying knocking on my doors when going over bumps, bizarrely enough it was cured with a bit of Vaseline on the door lock 'bar' (The fixed bar the lock 'bites around'.
Remember, if you ever need a helping hand, you'll find one at the end of your arm
DC
  • Switzerland
« Reply #5 on: 27 August 2009, 20:29:10 »
How exactly do you do it?
Gary W
  • Romford. Essex
« Reply #6 on: 28 August 2009, 23:57:42 »
Thanks for the info. l will look at adjusting the latch or striker plate.
