Author Topic: part No needed  (Read 1220 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
part No needed
« on: 28 August 2009, 22:28:38 »
n/s suspension has an idle arm. i urgentley need the corresponding arm on the o/s + part No would be great . thanks in advance.
Pete Elite
  • Uxbridge, Middlesex
Re: part No needed
« Reply #1 on: 28 August 2009, 22:54:38 »
Do you mean the anti roll bar link as the only idler i know of is the steering idler for which there is only the one :-?. If it is this you mean then they are the same for both side and can be got off of eBay for under a tenner :y.
 Although it being a diesel i may be wrong as i don't know a lot about there make up :(.
raywilb
    • Citroen C4 Cactus
Re: part No needed
« Reply #2 on: 28 August 2009, 23:24:30 »
not 100% certain but i think o/s is shorter on the tractors
raywilb
    • Citroen C4 Cactus
Re: part No needed
« Reply #3 on: 29 August 2009, 14:36:19 »
you are right the idle are the same both sides, was put on a bum steer by local motor factor. all done & dusted now. but detected slight movement with ball joint on the anti-roll bar (me thinks)  :y :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: part No needed
« Reply #4 on: 29 August 2009, 21:17:26 »
Errrrrr ...... steering idler is only on the nearside. Steering box arm is on the offside.
Are you not thinking of the tie-rods? - they have ball-joints on the ends.
« Last Edit: 29 August 2009, 21:20:04 by Reliance505 »
raywilb
    • Citroen C4 Cactus
Re: part No needed
« Reply #5 on: 30 August 2009, 17:45:03 »
it was the steering box arm, will attempt to fit in the morning noticed on further inspection the o/s anti roll bar balljoint is suspect.
