Author Topic: Brake lights permenently on  (Read 1527 times)
semisheen
  • Chesterfield
« on: 29 August 2009, 23:49:43 »
As above the brake lights come on whith the ignition looked at the pedal swith disconected it and they still come on
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: Brake lights permenently on
« Reply #1 on: 30 August 2009, 00:10:41 »
Was it connected correctly before you disconnected it, or loose?
 Changed any bulbs lately?
semisheen
  • Chesterfield
« Reply #2 on: 30 August 2009, 00:18:01 »
Yes Mate it hadnt been touched at all but thought i would have a look "as you do".....the only other thing is i changed it from automatic to manual box about 6 weeks ago but ive only just noticed as its getting dark nights but i cant really see how that could make the brake lights perminently on
3.2 manual
  • nr yeovil, somerset
  • the great thread ender! whoops
« Reply #3 on: 30 August 2009, 05:16:44 »
you could pull the fuse for the brake lights, this will tell you if its a short in the brakelight circuit or if its getting its power from somewhere else. i wouldnt recommend this for driving though, as people dont pay enough attention to the bright red lights anyway. single pole bulb in a double pole socket? this does it on trucks.
« Last Edit: 30 August 2009, 05:18:50 by lovelectricity »
oh bugger, i thought that was a bit of wind!!!
  • Auckland
    • Mazda MPV
« Reply #4 on: 30 August 2009, 08:29:53 »
On an auto you have to press the brake pedal before you can move the gear shifter out of 'park' & I think the box has to be in park or neutral before you can start it. Did you have to modify this wiring when you swapped the gearboxes?
semisheen
  • Chesterfield
« Reply #5 on: 30 August 2009, 17:59:15 »
Yeah sorted all the wiring out corectly even got the cruise to work afterwards .....ill be having a good luck around as soon as it stops raining
