Author Topic: Cruise Control - add on  (Read 1887 times)
Richard A
  • Aldridge, West Midlands
« on: 26 August 2009, 20:15:01 »
What is the cost/problems to adding 'cruise control' to a 2.2 petrol CD Omega ?
regards
richard a
richard a
webby23
  • Nottingham
  • MV6
Re: Cruise Control - add on
« Reply #1 on: 26 August 2009, 20:19:39 »
15 quid for the stalk ogg ebay richard then find a friendly tech 2 owner.........
Mark dtm did mine, no problems at all, works a treat.......
Richard A
« Reply #2 on: 26 August 2009, 20:28:12 »
Long Eaton !!
So 'Plank & Legett' not far away !!
Food for thought !
regards
richard a
richard a
3.2 manual
  • nr yeovil, somerset
  • the great thread ender! whoops
« Reply #3 on: 29 August 2009, 05:02:39 »
hi looking for nearest tech 2 member, stalk and clutch switch fitted its an 03 3.2, local car electronics place played for 20 mins yesterday then admitted failure. im in somerset, i think kevin wood is the closest. anyone know better?
« Last Edit: 29 August 2009, 05:04:56 by lovelectricity »
oh bugger, i thought that was a bit of wind!!!
« Reply #4 on: 29 August 2009, 20:20:02 »
Or a day (or weekend break :y) to Newent (nr Gloucester) next weekend for one of the big OOF weekend meets. See meetings section ;)
mathewst
  • Split, Croatia
    • v40
« Reply #5 on: 29 August 2009, 20:34:54 »
I guess you need something more than just stalk to fit a cruise control??
« Reply #6 on: 29 August 2009, 20:51:02 »
Depends on engine. 2.2/2.6/3.2 need cruise stalk, possibly clutch switch if manual, and a plug-in to a Tech2 to enable.
2.5td just needs cruise stalk
2.0/2.5/3.0 need the actuators and associated gubbins as well
3.2 manual
« Reply #7 on: 30 August 2009, 03:42:41 »
i had to fit the stalk, one of a senator or carlton seem to fit and all connections line up and plug in fine, cost one smashed up carlton, whoops( the real test will be to see if it works!) , and the clutch switch, this came off a v6 vectra again fitted and plugged in fine, cost £5 in local scrappy. now needs enabling in the computer. that should be about it. oh newent, driven through a few times will look in that section now.
cheers for that
« Last Edit: 30 August 2009, 03:47:14 by lovelectricity »
webby23
  • Nottingham
  • MV6
« Reply #8 on: 30 August 2009, 08:41:39 »
Long Eaton !!
Food for thought !
regards
richard a
Thats right Rich, you may not remember but I went there and met you and the others a few months ago at the OOF/ABS meet up
Richard A
« Reply #9 on: 30 August 2009, 09:53:43 »
Yes, see you again in September ! .
 I still have my '98 Elite, however it maybe a little long in the tooth (160k) for the miles I will start to cover.
Face-lift CD models seem very cheap but would need cruise control, 'tech2' not a problem i'm sure 'Dr Omega' would help out !
regards
richard a
richard a
« Reply #10 on: 30 August 2009, 11:58:30 »
cheers for that
the senator/carlton one from memory works, but stalk too long.  brand new from dealer, stalk is only £30ish
Richard A
« Reply #11 on: 30 August 2009, 20:48:19 »
Cheers, thanks for the information.
regards
richard a
richard a
