Author Topic: Stuck drivers door  (Read 1355 times)
diversteve
Stuck drivers door
« on: 31 August 2009, 10:17:13 »
Hi all, just wondering if anybody has a solution to a drivers door which I cannot open. Its seems that the central locking has deadlocked the door and I need to open it to take the door card off to fix it. Any helpful suggestions welcome. Car is a 2.6 cdx 2002
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Stuck drivers door
« Reply #1 on: 31 August 2009, 14:24:08 »
Being a Facelift, you should still be able to open it with the Key. Turn the key all the way to the right, will be a bit stiff but it will turn. The unlock button wont pop up but if you hold the door handle open while turning the key it should open.
Chris.
diversteve
« Reply #2 on: 31 August 2009, 17:55:01 »
Thanks a lot Chris, it worked..
Again, many thanks..
zirk
  • Epping Forest
« Reply #3 on: 01 September 2009, 13:43:39 »
Your welcome Steve,  :y
« Last Edit: 01 September 2009, 13:44:11 by zirk »
