Author Topic: How High....  (Read 3602 times)
How High....
« on: 31 August 2009, 18:42:21 »
.... or low, does the Omega need to be, in order to lift out (and then back in) an engine?
Any thoughts most welcome - I want to do my engine change as soon as I ever get time - but I've never done the job before  :y
The autobox is huge - will it really all go in as one unit?  :-?
  • Auckland
    • Mazda MPV
Re: How High....
« Reply #1 on: 31 August 2009, 19:06:09 »
Do you need to take the box out?
When I took the engine out of my manual Omega it seemed natural to drop the gearbox before lifting the engine. The engine is ridiculously heavy even without a gearbox attached.
With my old Range Rover the gearbox is such an awkward lump that I find it makes sense to lift the engine out first if I want to access the gearbox. The gearbox does rest nicely on the crossmember when separated  from the engine however.
« Last Edit: 31 August 2009, 19:09:46 by andyh »
Dazzler
  • Haverhill, Suffolk
Re: How High....
« Reply #2 on: 31 August 2009, 19:55:19 »
Take out engine on its own.
Remove rad and bag pipes etc..., then you have loadsa room ;)
Re: How High....
« Reply #3 on: 31 August 2009, 19:59:56 »
I'm game to do either - I just recall members saying they did theirs in one lump?
Omegatoy
  • UK
Re: How High....
« Reply #4 on: 31 August 2009, 20:04:46 »
just put the rear wheels up on ramps facing opposite ways James, this gives a very good angle to lift the engine and box out without having to lift it too high :y its far easier to take the whole lot out than splitting the engine and box in situ!!
« Last Edit: 31 August 2009, 20:05:08 by Omegatoy »
Re: How High....
« Reply #5 on: 31 August 2009, 20:17:59 »
Cheers G - does this involve leaving the fronts on the ground?
goonv6
Re: How High....
« Reply #6 on: 31 August 2009, 21:31:42 »
I took the bonnet off doing mine. Made things a whole lot easier.
Re: How High....
« Reply #7 on: 31 August 2009, 21:47:12 »
Yes, if I can get a i6 engine in and out with a gearbox attached, a v6 should be easy
Re: How High....
« Reply #8 on: 31 August 2009, 21:59:00 »
no need to jack up back.
see this
http://www.omegaowners.com/forum/YaBB.pl?num=1187475602/435#437
gones out nicely :)
Re: How High....
« Reply #9 on: 31 August 2009, 22:17:22 »
LOL, in looking for those pictures, I found myself going back 2yrs to the Project TB2 (Tractor) saga, and started rereading the update threads and the enormous 'Engine swap' threads :o
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: How High....
« Reply #10 on: 31 August 2009, 22:24:01 »
see this
gones out nicely :)
Two familiar faces there, the guy in the garage looks like he has been playing Rambo ;D ;D ;D
Re: How High....
« Reply #11 on: 31 August 2009, 22:29:31 »
see this
gones out nicely :)
Splattered in tractor blood ;D
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: How High....
« Reply #12 on: 31 August 2009, 22:33:18 »
see this
gones out nicely :)
"They drew first blood, not me!" ;D
goonv6
Re: How High....
« Reply #13 on: 31 August 2009, 23:55:38 »
Yes, it will but if you look at the angle TB's got it. Mine's manual so I separated the two but wish I hadn't. The only thing I would advise you is that the aircon pipe and brake pipe can foul when putting the V6 in. I wouldalso remove the cats completely. FWIW, I put the engine and gearbox in single handed, so it can be done but would strongly recommend a friend. :y
« Last Edit: 31 August 2009, 23:59:00 by goonv6 »
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: How High....
« Reply #14 on: 01 September 2009, 00:07:12 »
After the hassle we had trying to get the engine and gearbox back together I would say lift it out as one , We spent ages the first time we did the tractor trying to get the engine and box back together   :y
Blimey that doesnt seem that long ago
