Author Topic: 2.5 TD Timing chain and fuel pump..  (Read 1171 times)
AngryDog
« on: 02 September 2009, 10:03:22 »
Hi,
What sort of cost / job is it to change the timing chain / tensioners on a 2.5TD Omega?
Also, what about changing the fuel pump seals?
Thanks
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: 2.5 TD Timing chain and fuel pump..
« Reply #1 on: 02 September 2009, 10:18:56 »
Hi,
Thanks
Hmmm, I'm pretty sure that it means head and sump off, though I've not, (and hope not to have to), tackle this.
What fuel pump seals are you referring too?
« Reply #2 on: 02 September 2009, 19:59:48 »
Hi,
Thanks
That about sums it up
Omegatoy
  • UK
« Reply #3 on: 02 September 2009, 20:13:44 »
head does not have to come off!!!!!
its a fair bit of work t strip it whole timing cover comes off to give access to the chains and guides but you do need the special tool to hold the timing etc!!
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #4 on: 02 September 2009, 20:20:23 »
Made out of bits of Chez TB by any chance? ;D ;D
TuBy's new whipping boy.
« Reply #5 on: 02 September 2009, 22:52:32 »
depends how a stud (doesn't) come out, which is locited to block, meaning you have to lift head up over said stud.
