Author Topic: sagging on one side  (Read 1984 times)
matty
  • Nr Peterborough
sagging on one side
« on: 03 September 2009, 13:06:08 »
umm my omega seems to be sitting too low on one side,
about 20mm lower! any ideas? cant hear anything that could mean snapped spring
its a facelift v6
kris
  • manchester
Re: sagging on one side
« Reply #1 on: 03 September 2009, 13:08:41 »
more than likey a snapped spring. jack it up and whip the wheel off. happened to mine. couldnt tell till the wheels were off as the snapped bit had fallen off.
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« Reply #2 on: 03 September 2009, 13:09:43 »
Broken spring?? Mine has a broken spring and you would not hear any noises as i went over bumps, until i went under the car!
swamp rat
  • Cornwall
« Reply #3 on: 03 September 2009, 13:18:37 »
Yes spring. Had the same - the end of the spring was broken off and still sitting inside the coil. Wasn't aware of anything until I was looking underneath and spotted it.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #4 on: 03 September 2009, 13:21:27 »
I knew a woman like that once :D :D
matty
  • Nr Peterborough
« Reply #5 on: 03 September 2009, 13:49:36 »
time for some eibachs then
Selseybill
  • La Rochelle
    • 2.0 pre face, 2.2 CDX est
« Reply #6 on: 03 September 2009, 14:19:08 »
have a look at where you park,is it at a slant.try parking the other way around.the only reason i state this is my old estate used to lean to one side and after the garage couldn't find anything broke they asked me to park the car the other way around on the drive and hay presto within a week the car was level again.it was just due to the slant of the drive and the weight of the car made the suspension settle one way.I know it sounds crazy buy it worked for me
matty
  • Nr Peterborough
« Reply #7 on: 03 September 2009, 14:28:29 »
yep tried that mate, thanks though!
