Author Topic: he  (Read 1140 times)
jack russell
he
« on: 02 September 2009, 21:49:14 »
hello my 1996 omega falied mot on rear fog lights
not working fuse and bulbs ok no power at feed wires in boot is there a relay for  lights one by fuse box
are not the ones is there a relay some ware l seen some ware you can convert reversing light to fog
dont use fog lights any dodges l can do to pass mot
please tell me how[fog light  swith on dash  lights] thank you
Re: he
« Reply #1 on: 02 September 2009, 22:54:46 »
Not got wiring diag for 96 handy, but it is seperately fused. pretty certain there is a latching relay though.
Hopefully someone with a diag will be along shortly
Stevie-blunder
  • Wolverhampton
Re: he
« Reply #2 on: 03 September 2009, 00:26:18 »
I had exactly the same problem. Look at the wiring where it goes into the bootlid on the nearside hinge, broken wire ? reconnect it, sorted.  :y
3.2 manual
  • nr yeovil, somerset
  • the great thread ender! whoops
Re: he
« Reply #3 on: 03 September 2009, 04:02:20 »
i recently fitted a to bar, wired in no prob then found two black and blue wires in the plug got the multimeter out, both were live, so picked on at random. so far all good, all trailer lights worked including both fogs. looked at the car the nearside fogs out. then couldnt remember if id ever seen it light up. after bulb checks and much messin about joined to the two black and blues together( as in mine the n/s fog is joined to the o/s fog in the tow plug) then to trailer fog wire. hey presto all working, your problem is different but its a black and blue wire that goes to them. :y
oh bugger, i thought that was a bit of wind!!!
jack russell
Re: he
« Reply #4 on: 03 September 2009, 21:26:21 »
thanks for the sugestions on how to fix fog lights
time was short as time was nearly up on re test
 mot man told me if you wire up light on a switch
in car need not be linked to diped beam  it will pass mot  so thats what l done and got    that              important  bit of paper   thanks all
                                                somerset
