Author Topic: Strange smell  (Read 1395 times)
Ralph
  • Northumberland
    • 2.6 MV6
Strange smell
« on: 03 September 2009, 12:48:18 »
I've noticed an unpleasant smell in my car lately,
I wonder if this could be the pollen filter ?
How easy is it to change ?
Agemo
  • Cleethorpes
  • Insignia
Re: Strange smell
« Reply #1 on: 03 September 2009, 12:53:55 »
It's a doddle, but you probably have a drain blocked, so have a read of this:-
http://www.omegaowners.com/forum/YaBB.pl?num=1206287560
Make sure the drain is clear before you put a new filter in.
« Last Edit: 03 September 2009, 12:54:32 by Agemo »
Welung666
Re: Strange smell
« Reply #2 on: 03 September 2009, 13:18:25 »
Strange smell could be many things, depends on what it smells like.
Ralph
  • Northumberland
    • 2.6 MV6
Re: Strange smell
« Reply #3 on: 03 September 2009, 20:54:44 »
I've just noticed the passenger side rear floor is wet, the front appears relatively dry, I've had several people gietting in & out of front passenger side & given the recent weather conditions they will have all had wet feet. Can a blockage in the scuttle drain cause water to get to the rear floor without soaking the front first ?
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: Strange smell
« Reply #4 on: 03 September 2009, 21:09:24 »
I seem to remember Tunnie had a similar problem some time back and it was to do with the rubber door seal
 May be worth giving him a shout  :y
Re: Strange smell
« Reply #5 on: 03 September 2009, 22:31:19 »
also check door membrane behind door card is still sealed and the drains on the bottom edge of the door are not blocked
