Author Topic: 3.0 MV6 Fan Belt  (Read 1888 times)
star_whites
  • Rotherham
3.0 MV6 Fan Belt
« on: 04 September 2009, 22:38:02 »
Ok heres a strange one.
I recently ordered a replacment fan belt for my 3.0 MV6 1999. When it arrived I stripped her down only to find when I put it against the original it was longer. I didnt bother fitting this and rang my mate at vx. He said it should be the right one but there was one other option so he ordered that one. When it came I again stripped down only to find this was a good 2" too short  >:(
I again rang my mate and he has stated that there are only the two options and that it must be the longer one so he has swapped it me again. Now when I had it off last time I noticed that it was a genuine vx belt and wrote the numbers down only for vx to tell me that it dont exist  :-?
The part numbers issued are as below:
Origianl Belt (still fitted to car): FD912895 - 0826888
New Belt (longer than origianl): 93181720
New Belt (shorter that original): Didnt write it down!
Does anyone know what it should be??
Re: 3.0 MV6 Fan Belt
« Reply #1 on: 04 September 2009, 22:44:34 »
V6 with aircon part nº 93181720
V6 without aircon part nº 93181718 (same as 4pot with aircon)
HTH
« Last Edit: 04 September 2009, 22:44:59 by dbug »
star_whites
  • Rotherham
« Reply #2 on: 04 September 2009, 23:00:01 »
Ok I will give it a try in the morning then. It just appeared that there was too much play in the belt against the old belt. But I need to get it changed asap as it has gone really brittle and hard.
Dont want it snapping on me on the way to reading next weekend!
Pete Elite
  • Uxbridge, Middlesex
« Reply #3 on: 04 September 2009, 23:36:46 »
Hi,
   My 96 3.0L Auto with Aircon uses the 93181720 and i would have thought that this should be the one for yours as well :-?.
 I got the info. below from my EPC which doesn't even mention belt # 93181720 but instead 93181721 which I've highlighted:-?.
1  BELT,DRIVE,21.36 X 1900 MM,ALTERNATOR (IDENT FK) (NLS.- USE 9118618 OPEL 91126386VAUXHALL)
 EXCEPT AIR CONDITIONING X25XE,X30X   1  90409782  13 40 742
2  BELT,DRIVE,21.36 X 1900 MM,ALTERNATOR (IDENT FW) (NLS.- USE 9118618 OPEL 91126386VAUXHALL)
EXCEPT AIR CONDITIONING X25XE,X30X -W1193599
 1  90500228  13 40 614
4  BELT,DRIVE,21.36 X 1900 MM,ALTERNATOR (IDENT FX) (FOR DELETION OF AIR CONDITIONING PARTS) (FOR VAUXHALL) (NLS.- USE 93181719) X25XE,X30X W1193600-
 1  91126386
7  BELT,DRIVE,21.36 X 2260 MM,ALTERNATOR (FOR JAPAN) (IDENT FX) (NLS.- USE 9118620) (SEE SERVICE INSTRUCTIONS)
USED WITH AIR CONDITIONING X25XE,X30X R1000001-S1059678
 1  90500354  13 40 615
6  BELT,DRIVE,21.36 X 2020 MM,ALTERNATOR (IDENT AC) (USED WITH AIR CONDITIONING) (NLS.- USE 9118620) (EXCEPT VAUXHALL) X25XE,X30X S1059679-X1032987
 1  90528761  18 54 728
6  BELT,DRIVE,21.36 X 2020 MM,ALTERNATOR (IDENT AC) (USED WITH AIR CONDITIONING) (NLS.- USE 91126388) (FOR VAUXHALL) X25XE,X30X S1059679-X1032987
9  BELT,DRIVE,21.36 X 2020 MM,ALTERNATOR (IDENT FX) (USED WITH AIR CONDITIONING) (FOR VAUXHALL) (NLS.- USE 93181721) X25XE,Y26SE,X30XE,Y32S X1032988-
 1  91126388
10  ROLLER,TENSION (NLS.- USE 90528760) X25XE,X30X   1  90409783  13 40 536
10  ROLLER,TENSION (NLS.- USE 9202550) X25XE,Y26SE,X30XE,Y32S   1  90528760  13 40 547
10  ROLLER,TENSION X25XE,Y26SE,X30XE,Y32S   1  9202550  63 40 538
11  -PULLEY,TENSIONER X25XE,Y26SE,X30XE,Y32S   1  9157962  13 40 512
12  -SCREW,PULLEY,M10 X 30 X25XE,Y26SE,X30XE,Y32S   1  9157950  13 40 801
13  -NUT,PULLEY,M10 (NLS.- USE 12992580) X25XE,Y26SE,X30XE,Y32S   1  9157951  13 40 802
13  -NUT,PULLEY,M10 X25XE,Y26SE,X30XE,Y32S   1  12992580  13 40 832
14  -COVER,PROTECTION,TENSIONER X25XE,Y26SE,X30XE,Y32S   1  9157963  13 41 667
         HTH,
               Pete :).
  PS. It seems to me that both the belts that dbug has mentioned have had the last digit added to by 1 in the EPC that I've shown, Very odd :-?.
« Last Edit: 04 September 2009, 23:43:14 by scooby »
robbo299
  • luton, beds
« Reply #4 on: 04 September 2009, 23:44:53 »
The belt for the car WITH air con is 30mm longer than the one for a car without if that is any help. :y
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #5 on: 05 September 2009, 00:31:34 »
The one just fitted to my 98 Elite V6 3.0
 was number....93181720  Daz fit it but make a oint of saying it felt bloody tight when getting it on ! :y
star_whites
  • Rotherham
« Reply #6 on: 05 September 2009, 19:50:01 »
Ok update!
Stripped and fitted belt this afternoon  :y was extremly tight like you said but went on ok.
Also decided to look at leaking manifold while I was at it but not much success there  :-/ The bolts to the remoaining heatshields snapped off and couldnt get to the rear bolt right at the back so put her back together. Im guessing that there must be a crack in the manifold as I cant see anythere where its leaking so need to find a replacment. Then I will strip it all down as need to remove the large steel waterpipe from the back of the engine to give enough room to reach all the bolts. Then hopefully I can cure the leak that really annoys me!!!!  ::)
