Author Topic: Running temp ?  (Read 1071 times)
samrey4u
  • norwich
  • Big stranglers fan
    • 2003 2.2 cd saloon
Running temp ?
« on: 06 September 2009, 08:38:55 »
Car seems to be running cooler than normal at around 80 , what should i be checking for i.e thermostat ? :-/
sam
Welung666
Re: Running temp ?
« Reply #1 on: 06 September 2009, 08:54:23 »
The needle should sit around the middle of the gauge once it's warmed up, if it's not getting that far then could be thermostat stuck open. Does it take a long time to warm up?
samrey4u
  • norwich
Re: Running temp ?
« Reply #2 on: 06 September 2009, 08:55:58 »
yes it seems to take a while to warm up, it used to be about a mile down the road and was at normal temp  :-/ when i say warm up it stays around 80
« Last Edit: 06 September 2009, 08:56:33 by samrey4u »
sam
Welung666
Re: Running temp ?
« Reply #3 on: 06 September 2009, 08:58:48 »
I'd start with changing the thermostat, if it's stuck open (as I think it is) it's letting the warming water from the block out into the rad thus cooling it before it is needing to be cooled. This will mean it'll take ages to warm up and use more fuel in doing so. HTH :y
samrey4u
  • norwich
Re: Running temp ?
« Reply #4 on: 06 September 2009, 09:03:03 »
is the thermostat an easy job . if so will attempt it today , local motor factors are open  :y oops silly me i have a haynes manual to work from lol :D
« Last Edit: 06 September 2009, 09:03:41 by samrey4u »
sam
Mike Collins
  • North of Bristol
Re: Running temp ?
« Reply #5 on: 06 September 2009, 21:07:39 »
Thermostat change is not a quick job, whatever else you do, when you remove the old one don't refit it because it looks closed.
Mine have always seemed ok when removed but a replacement has always cured cold runnig.
