Author Topic: Replacing 2.5td Thermostat  (Read 1562 times)
DJ Pete
  • Chelmsford, Essex.
« on: 03 September 2009, 13:28:21 »
Hello All,
Have been replacing my thermostat today due to overheating issues, however, upon replacing with a new o ring, the housing leaks.
Should I be using a gasket, or would black or grey Loctite do the trick?
Thanks in advance,
Pete.
platty
  • Cambridge
    • BMW 530d Sport
Re: Replacing 2.5td Thermostat
« Reply #1 on: 03 September 2009, 14:24:03 »
Hi Pete,
Are you sure the ring is seated correctly? If it is not then it will cause a weep. Did you use a genuine kit and replace the seal?
Platty
johnhumid1
« Reply #2 on: 05 September 2009, 12:59:20 »
Replacing the thermostat due to overheating issues and upon replacing with a new o ring, the housing leaks. i guess the part you have replace may not fitted on it...
_________________
Humidifier filters
osealy
  • dublin
« Reply #3 on: 05 September 2009, 18:42:28 »
I replaced mine , the new stat came without an o ring so I used blue hylomar. Worked fine, also changed the pump.
Had to fit new rad in the end to cure overheating, been good now for 15k.
ferrari jason
  • Skelmersdale
« Reply #4 on: 05 September 2009, 19:16:04 »
Hi mate i did one on my old 2.5 td last year and the o ring hadn`t quit seated properley and it dripped took it all apart again and used a  new o ring and no sealer it worked perfect
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #5 on: 06 September 2009, 21:30:19 »
Sounds like the black plastic housing is not seating correctly to it's mating face. These are not usually problematic.
DJ Pete
« Reply #6 on: 06 September 2009, 22:39:04 »
I must have not seated it properly, worked fine when I redid it.
Thanks for advice.
