Author Topic: Coolant Level warning Display  (Read 1576 times)
puffa
  • Southampton, UK
« on: 11 September 2009, 19:44:27 »
About three days ago the mig started to display coolant level directly after the check brake when starting the car up each time, I have checked the coolant levels daily since and have also been checking the roads surface for coolant discharge, however nothing abnormal is happening, it is not running any hotter than normal but still displays coolant check directly after start up, it doesnt display it at any other time.
Has anyone else experienced this ?
Is there a sensor somewhere that could be faulty, if so where?
Steve
Previously owned 2.5 v6 Reflection
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Re: Coolant Level warning Display
« Reply #1 on: 11 September 2009, 19:45:17 »
Sensor is integral to the coolant bottle :y
puffa
  • Southampton, UK
« Reply #2 on: 11 September 2009, 19:48:05 »
Is that the float type thing you can see through the fill cap hole, do you have to replace the entire tank to change it?
steve
Welung666
« Reply #3 on: 11 September 2009, 20:05:02 »
steve
Yes unfortunately :(
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #4 on: 11 September 2009, 23:28:12 »
Had just the same with mine  l had to replace with the a new header tank about £25 for Vax can be done without lose of coolant . All was good after the replacement :y
puffa
  • Southampton, UK
« Reply #5 on: 12 September 2009, 10:00:21 »
off to vauxhall for a header tank it is then ... cheers guys and gals
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #6 on: 12 September 2009, 13:18:02 »
Check the sensor plug underneath is not intermittant / fallen off first.
