Pages: [1] 2 3  All   Go Down
Author Topic: My Car Will Not Start DESPARATELY NEED HELP  (Read 6870 times)
Risky Duckfeet
  • High Wycombe
  • Don't look behind you!!!
« on: 06 September 2009, 12:02:10 »
Hi All,
Got in the car this morning and it wouldn't start. It was turning over perfectly but would not fire, not even a splutter. I need the car to be working for tomorrow and have not got a clue what is wrong.
Seemed a bit funny yesterday, had to have a couple of attempts at starting a couple of times.
Is ther a safety fuel cut off switch anywhere, or could it be a relay problem preventing power getting to the ignition?
Would really appreciate any help that I can get.
Thanks, Kieren
« Last Edit: 06 September 2009, 17:33:57 by riskyduckfeet »
Welung666
Re: My Car Will Not Start
« Reply #1 on: 06 September 2009, 12:03:39 »
Morning Kieren, do the paperclip test on it (see my signature) and report back with any codes :y
patriotste
  • Stockport
« Reply #2 on: 06 September 2009, 12:21:55 »
Crankshaft sensor is favourite,but check codes first.
Risky Duckfeet
  • High Wycombe
« Reply #3 on: 06 September 2009, 12:27:07 »
Hi, Should have said, I did the paperclip test first thing and the results were 12 and 31 so it didn't really help much.
Welung666
« Reply #4 on: 06 September 2009, 13:33:07 »
Still could be crank sensor, they sometimes go without showing a code. Give as much of the crank sensor wiring you can get to a shake and check the plug (near the pass. side at the rear of the plenum and just under the skuttle) is located tightly and no water in it :y
Risky Duckfeet
  • High Wycombe
« Reply #5 on: 06 September 2009, 13:49:22 »
i'll give that a go now and get back with the results.
Risky Duckfeet
  • High Wycombe
« Reply #6 on: 06 September 2009, 14:12:38 »
Wasn't surewhich was the crank senser, but I pulled about some wiring under the skuttle. There was one connector that has fallen apart a little bit. Looks like a three pole connector and one end has what looks liike a vacuum hose. But nothing has changed, not sure if I was looking in the right place. :(
Risky Duckfeet
  • High Wycombe
« Reply #7 on: 06 September 2009, 15:13:25 »
Bloke has just been around from the breakdown cover I have. He took off the fuel lines from the engine and got me to turn the engine over, then said that it was the fuel pump. Just then a noise started coming from the engine bay next to where the battery is. He said it was the cooling system, I said it sounds like a faulty relay. We had a look through the manual and couldn't work out which relays were which. Then I said could the problem be that the crank senser is what tells the pump to start pumping........
He says, to be honest mate, I'm not really a mechanic so I couldn't tell you.
That's where we got to >:(
Any ideas? If it is a relay that controlls the fuel pump does anyone know which one it might be?
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #8 on: 06 September 2009, 16:36:04 »
Hi try this one it might be either no. 10 or 20
http://www.omegaowners.com/forum/YaBB.pl?num=1176560725
Hope it helps a bit. take the relays out and check there is no corrosion on the contacts.
also check the fuse it might be knackered.
http://www.omegaowners.com/forum/YaBB.pl?num=1161602008
« Last Edit: 06 September 2009, 16:38:44 by acdcdave »
He who brakes Looses
To old to die young
Risky Duckfeet
  • High Wycombe
« Reply #9 on: 06 September 2009, 17:28:13 »
Thanks mate but I've just been out and had it all in bits. I can hear the fuel system running when I closed the fuel pump relay circuit and I swaped the two relays between the pump circuit and the injection circuit.
Taken the skuttle out and had a poke around behind but still no joy. Doing my head in now.
Which leads me to--- Does the immobiliser cut out the ignition completely or does the starter still work?
Has anybody at all got any other ideas? (That do not involve Torx sockets)
Running out of time and really nood to get running by the time I go to bed.
Thanks for all the help so far. :y :'( :o :-[ [smiley=dankk2.gif]
Re: My Car Will Not Start DESPARATELY NEED HELP
« Reply #10 on: 06 September 2009, 17:39:52 »
Crank sensor is always the suspect when they wont go,Unfortunately the only way I know of finding out is to swap with a known good one,not sure if any members near you who might be able to assist. :-/
Ghost
    • 2.6 V6 CDX Estate
« Reply #11 on: 06 September 2009, 18:05:35 »
Heres a pic of the cs sensor plug, its on the pas. side
To old to die young
Risky Duckfeet
  • High Wycombe
« Reply #12 on: 06 September 2009, 18:07:37 »
Thanks mate, I'm not even sure what it looks like, I can't find it in the manual.
IS THERE ANYONE NEAR ME THAT IS LONELY?????????? I WILL BE YOUR FRIEND!!!!! JUST SAVE ME.
Risky Duckfeet
  • High Wycombe
« Reply #13 on: 06 September 2009, 18:10:08 »
Thanks, that is the plug that I was playing with, it had fallen apart to a degree and I have put it back together. Is there an easy way of making sure that it is dry?
Dave-C
  • Staffordshire
  • The Old Girl
« Reply #14 on: 06 September 2009, 19:38:41 »
Is this sorted now then ?
Pages: [1] 2 3  All   Go Up
