Author Topic: Help ENGINE PROBLEM  (Read 4601 times)
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Help ENGINE PROBLEM
« on: 11 September 2009, 12:02:03 »
Hi I have a 2.0I 16V eco engine, the management light keeps being on I have changed the cam sensor and air flow meter as they tested wrong, now when you disconect the battery then connect it again, start the engine no light 5-10seconds in the light comes on again there was a bit of oil in the sensor on the bottom of the engine behind the oil filter so clean'd that out still no joy, it allso will not go above 4, 1/2 on the revs acting like there is is no fuel getting there and rocks the engine, idles ok there is pressure in the line is ok filters are ok spark plugs and leads ok every thing thing seem ok but there is the fault still can any one help thanks. :-[ :'( [smiley=undecided.gif]
« Last Edit: 11 September 2009, 12:02:52 by Russell_Hill »
serek
  • huntingdon
    • 3.2 mv6
Re: Help ENGINE PROBLEM
« Reply #1 on: 11 September 2009, 12:13:15 »
sound like cam sensor gone. try code read first :y
« Reply #2 on: 11 September 2009, 12:15:52 »
If genuine cam sensor was fitted, check cabling and connection. Wouldn`t hurt to paperclip it again. Symptons appear to be cam sensor related :y
« Reply #3 on: 11 September 2009, 12:16:45 »
Must type quicker with shorter explanation ;D ;D ;D
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #4 on: 11 September 2009, 12:21:57 »
Like the others say,  sensor, I had the same problem with my car.
He who brakes Looses
To old to die young
rustym95
« Reply #5 on: 11 September 2009, 15:08:00 »
Hi again, its a new cam sensor, checked the wire to ecu that was ok, is there a way of removing the codes from the manager, some one i think said do it, 25 turns of the key or is there an easyer way. thanks
« Reply #6 on: 11 September 2009, 15:11:11 »
geniune or pattern sensor?
rustym95
« Reply #7 on: 11 September 2009, 15:14:28 »
its a genuine make from vauxhall.
rustym95
« Reply #8 on: 11 September 2009, 15:23:40 »
I have even checkedn the ECU and itcomes up on the test as good, but only got a tester not a recoder, I put a new air flow metre on as when removed it did nothing to the engine, now new 1 dose, cheacke and ajusted cambelt as was out would the crank sensor do this cos of alle the wire pulling I cannot emty the mem on management.
rustym95
« Reply #9 on: 11 September 2009, 18:15:59 »
Hello again Ive just been out into town and back, light still on so did paper clip test its got me confusted did it as video says and it gose like this as it cam up, 2 3 3 3 3 3 2 6 7 1 7 1 7 3 7 3 7 3 9 1 9 1 9 1 1 1 1 3 3 2 1 2 2 7 7 1 7 1 7 3 7 3 7 3 9 2 9 2 9 1 1 2 1 2 1 1 2 2 2 1 7 1 7 1 7 1 7 1 7 3 7 3 72 9 2 10 1 9, there was more but it was doing me head in dose any one have the foggiest wot this all means thanks :-X :(
rustym95
« Reply #10 on: 11 September 2009, 18:50:21 »
Hi he wife just did it for me just in case i got it wrong and there seams to be a theme going on did start up number then dose a lot of 1 2 and 1 7, 1 9, have not got a clue what it all means. any 1 please. :-/ :-/ :-/
Ziad
  • Bahrain
« Reply #11 on: 11 September 2009, 23:20:12 »
12 - Start of sequence
19 - Incorrect Revs per Minute (RPM) signal (crankshaft sensor) Incorrect signal, check sensor
17 - i aint have any idea
Check link below for more details matey:
http://www.omegaowners.com/forum/YaBB.pl?num=1207565476
Cheers
Ziad  :y
rustym95
« Reply #12 on: 12 September 2009, 08:33:03 »
Thanks M8 Ill have a look at that, just going round cleaning ev cable in and around the engine, were is the crankshaft sensor is it on left side or the right side, could it have dun somthing when i went in a ford the other week, thanks any way Ziad :y :y
rustym95
« Reply #13 on: 12 September 2009, 10:05:05 »
ziad m8 checked the sensor seems to be fine, have go throw the hole sensor cannot find a folt with any of them might just get a new ECU it my have a fault that dont come up, the more i look at the numbers coming up just seems funny that ev thing on the engine is coming up even numbers that are not on that list you sent me, thanks m8, going out on monday see how it gose ether way if it conks out ill call the RAC they get me home lol. thanks again.
Wolfman
  • Hucknall, Nottingham
« Reply #14 on: 12 September 2009, 10:59:02 »
Hi Rustyman
If you need ECU checking pm me.
I do decodes and repairs, remaps on ECU'S
Regards
Hodgy
