Author Topic: Strange pulsating noise at low speed  (Read 901 times)
mobby.6kl
« on: 13 September 2009, 11:03:09 »
Looks like it's time for another problem. Since the last time I posted with a problem here, I had the rear left wheel bearing replaced, and the headlight leveling system reported an error but then somehow fixed itself  :)
Now there's another problem. From about 20 km/h there's a weird, pulsating noise coming from somewhere which is probably the loudest at around 30km/h, but then quickly disappears as I accelerate. It's hard to describe, as I said it's pulsating, as if something was grinding only at a particular spot during rotation. The noise appears to be dependent on road speed and not engine speed, as I can let it drop to ~1k RPM when going downhill or coasting to a stop.
I tried to record the sound with my phone, so hopefully it's good enough to hear what's going on.
Download the mp3 here.
 From a complete stop I slowly get up to about 25-30 km/h and stay there for a bit (from about 8-10 seconds), then accelerate to about 70 just to see that the noise isn't there. You can also heart it at the very end when I slow down into a turn. The noise isn't necessarily as loud or as quiet as it might sound, as I messed with the volume in a sound editor.
To me this sounds nothing like how the bearing did, although I didn't get to try the usual tests (sharp turns, etc). There are also some quite ticking noises at the beginning, but I suspect that's just the key chain banging on something. The car is a 2001 Caravan 2.2 automatic, with about 145k km. So, any suggestions what might be causing this, or what can I do to try to find out? Thanks.
Selseybill
  • La Rochelle
    • 2.0 pre face, 2.2 CDX est
Re: Strange pulsating noise at low speed
« Reply #1 on: 13 September 2009, 11:44:52 »
i had the same ticking noise on a london taxi i used to own.if sounded like there was stones stuck in the tread then started to droan .turned out to be a wheel bearing in the end or should i say what was left of it
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #2 on: 13 September 2009, 12:45:10 »
Sorry mate I cant here any noises apart from the ones your making,
Have a good look at all four wheels and round them see if theres anything that looks or feels odd.
He who brakes Looses
To old to die young
Page created in 0.024 seconds with 16 queries.
