Author Topic: suspension noise  (Read 1424 times)
robbo2345
  • Norfolk
  • the nature of the beast
    • 01/03 elite 2.6 estates
suspension noise
« on: 16 September 2009, 23:04:14 »
hi i have a knocking sound on the front suspension occasionally also tyres get cut out on the outside edges after 3500-4000 miles, does anyone know what the problem is any help would be much appreciated ! cheers
life is too short ...... so live it every day !!
al brown
  • alton, hants
    • Rusty 97 3l estate
Re: suspension noise
« Reply #1 on: 16 September 2009, 23:15:00 »
Hi and welcome. Knocking is most likely one of the drop links on the front end, 2 nuts and about £8 to buy. Inside edge wear is normally wishbone bushes from advice on the forum. Easyer to change the whole wishbone and not too expensive, I paid about £55 for the pair. There is a guide in the maint section for both jobs.
Al
If it aint broken, you aint trying hard enough
robbo2345
  • Norfolk
« Reply #2 on: 16 September 2009, 23:24:07 »
cheers for that andy ! :y :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #3 on: 16 September 2009, 23:27:54 »
Hmmm, worn bushes usually cause wear on the inside of tyres, if the outside is wearing, either your tracking or camber is out. Best check for wear anyway, & if you change wishbones and/or droplinks, have wheel alignment checked asap.
« Last Edit: 16 September 2009, 23:28:35 by Agemo »
robbo2345
  • Norfolk
« Reply #4 on: 16 September 2009, 23:41:17 »
thanks again guys wish i had found this place before! just paid out £438 for a manifold gasket! :y
