Author Topic: CODE 61 HELP  (Read 1464 times)
lee4206
  • southampton
  • Mot Tester
    • 2000 3.0l manual MV6
CODE 61 HELP
« on: 19 September 2009, 14:51:08 »
Im getting a code           61   Fuel Tank Ventilation Valve Voltage Low
does anone have any ideas what i can do to get rid of it??
It was fine last time i drove the car but its been off the road for a couple of weeks with the plenum and leads removed.  Put new leads on and fired up today with this code.   I've reset it a couple of time and it keeps coming back so it is current.
Any help or advice welcome.
Lee
Re: CODE 61 HELP
« Reply #1 on: 19 September 2009, 15:36:57 »
Check the connection to the purge valve, rear of R/H cyl. head and vac pipe connections
« Last Edit: 19 September 2009, 17:29:36 by RobG »
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: CODE 61 HELP
« Reply #2 on: 19 September 2009, 17:07:46 »
Could try and see if it gose away with the perol cap off and engie running, if it works check the pipe under the tank.
lee4206
  • southampton
  • Mot Tester
Re: CODE 61 HELP
« Reply #3 on: 19 September 2009, 20:14:59 »
Cheers Rob the connector had come off back on and clear now.
lee
Re: CODE 61 HELP
« Reply #4 on: 19 September 2009, 20:18:34 »
lee
Look for the obvious first. :y :y :y :y
lee4206
  • southampton
  • Mot Tester
Re: CODE 61 HELP
« Reply #5 on: 19 September 2009, 20:27:11 »
lee
 :y :y
I did check all of the vac pipes and found the one that comes from the purge valve was on the wrong on the plenum sorted that and no change but its very hard to see or get to the connector on the valve with the plenum on so it wasnt obvious.
Re: CODE 61 HELP
« Reply #6 on: 19 September 2009, 20:30:57 »
lee
 :y :y
Didn`t mean to sound sarcastic. Just meant whatever the code relates to have a gander in that general area :)
lee4206
  • southampton
  • Mot Tester
Re: CODE 61 HELP
« Reply #7 on: 19 September 2009, 20:38:25 »
lee
 :y :y
Wasnt taken as such or applying you were being rob.
Just agreeing with check the obvious first  :y
Re: CODE 61 HELP
« Reply #8 on: 19 September 2009, 20:41:44 »
No probs Lee :y
« Last Edit: 19 September 2009, 20:42:05 by RobG »
