Author Topic: How do I remove lambda from RHS, looks impossible  (Read 1123 times)
Martin_1962
« on: 18 September 2009, 20:43:17 »
Had a look today, gasket on passenger side was quite easy, gearbox pipes mean I cannot get to the drivers side lamda - any suggestions please?
damon80
  • Wigan
Re: How do I remove lambda from RHS, looks impossible
« Reply #1 on: 18 September 2009, 22:15:13 »
I take it yours is an Auto? (Had a look at mine when mine was up on the ramps having it's new exhaust fitted, and both lambda's on both banks looked easy enough to get off).
Could you get to it with an angled ring spanner??  :-/
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #2 on: 19 September 2009, 00:04:45 »
Hi there there is a tool you need to get if its hard to get at looks like a bent spanner but it has a swivel bit in the middle, seen it in mag other week they use them alot now makes it easy to get at any bolt or nut, think they have them on ebay but cannon remember its name. :y :y
Martin_1962
« Reply #3 on: 19 September 2009, 20:07:22 »
Yes auto.
Didn't even try to get a spanner in there - no room to swing it.
Might see if the error goes after fixing the other banks exhaust leak.
Just wondering if oil burning could hav caused it (stem seal problem which triggered the rebuild)
rustym95
« Reply #4 on: 19 September 2009, 20:52:21 »
could be, can u pressure wash the underneath the car, blow all the muck away, not wax repeat not wax, can damage the cat. :y
