Author Topic: leeking injector 2.5 cdx  (Read 1199 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« on: 19 September 2009, 10:38:43 »
hi bought a 2.5 cdx and discovered it has a leaking injector,think its no1 and has left a small puddle of diesel in the injector housing.any ideas on how to fix or replace?any help greatly appreciated! :y
scream if you want to go faster!!!
Wolfman
  • Hucknall, Nottingham
Re: leeking injector 2.5 cdx
« Reply #1 on: 19 September 2009, 12:15:07 »
Hi
Are you sure its not the return pipes leaking, The pipe that goes from injector to injector. Failing that just nip up the feed pipe and or the injector.
Hodgy
« Last Edit: 19 September 2009, 17:47:07 by Hodgy »
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #2 on: 19 September 2009, 17:42:48 »
Sounds like the leak-off pipes ........
Get a metre length from factors, and change the lot. Cheap as chips!
mr ICE man
  • dolgellau wales
« Reply #3 on: 19 September 2009, 21:33:53 »
will have a look in the morning thaks all!
